 Post subject: WD1600JB Module Header Error
PostPosted: March 3rd, 2011, 13:34
Hello Gurus,
Could any one please have a look at the following log and give a direction to fix it using PC-3000 UDMA?
Model: WDC WD1600JB-00GVA0
Donor PCB with the ROM from the orignal burned PCB
Status:
still cannot be recognized by computer
In PC-3000 UDMA:
Get ready after 40 seconds
Heads test....ok
Resorce backup, some errors in -19 and -20 Cyl
SA Structure Test: Some module errors
Techno mode key:
HDD geometry loading.................... : Ok
Cyl Count............................... : 83970
Head Count.............................. : 4
SPT..................................... : 900
RAM:
Zone allocation table................... : Ok
ROM version............................. : 08.E4.
SA FW version........................... : 08.E4D
Link table version...................... : 02.GA.
Serial ROM:
Read ROM................................ : Ok
Heads configuration..................... : From map
Heads number............................ : 6
The number of heads in use.............. : 4
Disabled heads.......................... : Yes
Head map................................ : 0,1,4,5
Service area:
Modules table loading................... : Ok (Copy 0)
Configuration loading................... : Ok
Master Password......................... : "WDCWDCWDCWDCWDCWDCWDCWDCWDCWDCWD"
User Password........................... : has not been set
Translation overlay checking............ : Ok
HDD resources backup
Reading service tracks
Everything ok except.
Cyl -19; Head 1......................... : Ok
WD Techno Read Error C/H/S: -20/0/1 Device Error Detected 59/01 (AMN)
WD Techno Read Error C/H/S: -20/0/11 Device Error Detected 59/01 (AMN)
Cyl -20; Head 0......................... : Ok
WD Techno Read Error C/H/S: -20/1/1 Device Error Detected 59/01 (AMN)
WD Techno Read Error C/H/S: -20/1/10 Device Error Detected 59/01 (AMN)
WD Techno Read Error C/H/S: -20/1/11 Device Error Detected 59/01 (AMN)
Cyl -20; Head 1......................... : Ok
Backup process completed
SA surface verification
Initial cylinder........................ : -1
Final cylinder.......................... : -20
Head.................................... : 0,1
SA surface verification completed
Heads test
Cylinder to test........................ : -25
Heads to test........................... : 0,1,4,5
Head 0.................................. : Ok
Head 1.................................. : Ok
Head 4.................................. : Ok
Head 5.................................. : Ok
SA structure test
Module 3C Copy 0........................ : Header error
Module 3C Copy 1........................ : Header error
Module 38 Copy 0........................ : Header error
Module 38 Copy 1........................ : Header error
Module 30 Copy 0........................ : Header error
Module 30 Copy 1........................ : Header error
Module 34 Copy 0........................ : Header error
Module 34 Copy 1........................ : Header error
Module 45 Copy 0........................ : Header error
Module 45 Copy 1........................ : Header error
Module 01 Copy 0........................ : Header error
Module 01 Copy 1........................ : Header error
Module 10 Copy 0........................ : Header error
Module 10 Copy 1........................ : Header error
Module 22 Copy 0........................ : Header error
Module 22 Copy 1........................ : Header error
Module 23 Copy 0........................ : Header error
Module 23 Copy 1........................ : Header error
Module 46 Copy 0........................ : Header error
Module 46 Copy 1........................ : Header error
SA structure checking has been completed
Reading modules
Into folder............................. : <HDD Profile>\Data\Modules\
Reading method.......................... : Composite reading
All Modules : ............................. : Ok
Into folder............................. : <HDD Profile>\Data\Tracks
Reading heads........................... : 0,1
All OK except:
 Post subject: Re: WD1600JB Module Header Error
PostPosted: March 3rd, 2011, 15:18
Some messed up SA.
www.datarecoveryne.com
PostPosted: March 3rd, 2011, 16:49
Imagine a surgeon injecting you with general anaesthesia, while you count down from 5 to 1 you hear him ask "What does a scalpel look like?" :shock:
PostPosted: March 3rd, 2011, 18:01
Thanks, you guys. Seems no cure for this patient.
PostPosted: March 3rd, 2011, 20:42
There is a cure, but have to work with it.
PostPosted: March 8th, 2011, 11:24
I got all the data. Thanks.
