 Post subject: Seagate St31000528AS
PostPosted: May 18th, 2011, 13:55
i have Seagate St31000528AS drive , using pc3k clone up to 351000000 sectors and then after that it does not read it at all . any clue or help will be appreciated
 Post subject: Re: Seagate St31000528AS
PostPosted: May 18th, 2011, 18:32
Did the drive had Size 0 or LED CC problem before ?
PostPosted: May 19th, 2011, 13:53
Yes it had bsy problem.
PostPosted: May 19th, 2011, 15:50
Congrats - you killed it
I believe PC3K has some sort of procedure to fix that kind of problem but on this drive it may take forever
PostPosted: May 20th, 2011, 3:08
There's PC3K way to try to solve it.
And there's also a manual way to do it, but it's not easy.
PostPosted: May 22nd, 2011, 14:36
Tried the Pc3k way read a bit more sectors. Any help will be appreciated
PostPosted: May 23rd, 2011, 3:38
From now up I don't think there's much more options than a manual way of doing it.
PostPosted: May 26th, 2011, 5:32
You can try to read by terminal but very very slow.
* Có ba thứ ngu dốt :
Không hiểu biết những gì mình đáng biết.
Hiểu biết không rành những gì mình biết.
Hiểu biết những gì mình không cần biết.
