 Post subject: HD082GJ with module´s problem.
PostPosted: November 25th, 2011, 21:47
How can i fix this problem using pc3k-pci v2.4???
Tks
 Post subject: Re: HD082GJ with module´s problem.
PostPosted: November 26th, 2011, 8:56
What´s the first step to detect module's problem???
PostPosted: November 26th, 2011, 13:20
Pc3k comes with manual. Check it out. Plenty of info there.
PostPosted: November 29th, 2011, 12:52
You need to explain your problem in more detail. The more generic you are the less of a response you will get back.
Also as you have PCI PC3000 you should check it actually supports the model of HDD you are working with.
PostPosted: December 4th, 2011, 6:22
tks for all
