 Post subject: Problem with Seagate ST91208220AS Momentus PSD 120Gb
PostPosted: April 23rd, 2010, 6:46
Hi to all.
I have a strange problem with that Seagate HDD. When i connect it to Pc3K, and power on, it start normally and no knock i can ear ( I can ear normal heads sound for start positioning, too). The problem is that the Hdd stay in Busy state.
I see the terminal report at power on, is like the follow :
Reset
4096k x 16 DRAM
LARAMIE - 1_Disk S-1F 07-09-07_13:15
HM SFI
(P)
.FSTOP(0, 2400).FA_State(0).FA_CNT(3)
LBA(FFFFFE87).LEC(0).X(18).PG(1EEF6),SABNR(88).VBM(3C88).SAVH(88,88).HVBM(3C60),LVBM(3C60).ERROUT
TblRdErr
NVC:Reconstructing
LBA(FFFFFE87).LEC(0).X(18).PG(1EEF6),SABNR(118).VBM(3C88).SAVH(118,118).HVBM(3BD0),LVBM(3BD0).ERROUT
TblRdErr
Some one can help me to solve this issue ?
Thank you very mutch to all !! :D
 Post subject: Re: Problem with Seagate ST91208220AS Momentus PSD 120Gb
PostPosted: April 23rd, 2010, 7:05
I have not seen Laramie for a while now :)
I think is likely that ROM may be damaged, but is not the only possibility. More thorough diagnostics are needed.
PostPosted: April 23rd, 2010, 7:12
May be :?
Have you that firmware ? The correct version is 3.ALE
THank you
PostPosted: April 24th, 2010, 5:24
Online
It is not ROM problem.
See PM.
PostPosted: April 28th, 2010, 15:10
I have the exact same problem here. Everything sounds normal so I am hoping I can fix this without opening the drive.
Thanks for your help :D
PostPosted: April 30th, 2010, 3:11
That error is related a ROM corruprion. I solved the problem to use a donor PCB with same ROM version. For me that is the only way to solve it.
Thank you at all.
Bye
PostPosted: April 30th, 2010, 6:47
Good Job :wink:
PostPosted: April 30th, 2010, 7:12
Good to know :)
ZeBong
" Россия еще раз"
PostPosted: October 30th, 2010, 15:26
Sometime it is a little difficult to find a donor PCB, and I have another solution.
If somebody else is interesting in this, we can make a deal to exchange "this trick" :D
PostPosted: November 20th, 2010, 6:25
Hallo
great forum :idea:
first, sorry for my bad english
i have the same Problem. Can anybody help me please ?
thank you.
bye
checkout
PostPosted: September 18th, 2011, 3:10
I have a ST91608220AS (SEAGATE Momentus PSD 160GB) with these effects.
The terminal-output is the following:
Reset
4096k x 16 DRAM
Buzz HM SFI
(P)$($0E06C,0DC89,0000,02,18,50,0E)(R70X:8C,27,38,0D,0A,8C,27,38,0D,0A,0001,0000
)SFI
AMR
$($0DC89,10C7E,0000,00,27,08,0C)$($0DC89,10C7E,0000,00,2B,14,0C)$($0DC89,10C7E,0
000,00,2B,14,0C)(R70X:8C,27,38,0D,0A,8C,27,38,0D,0A,0002,0000)SFI
AMR
.FSTOP(0, 2400).FA_State(0).FA_CNT(1)
LBA(FFFFFE17).LEC(0).X(8).PG(9C22),SABNR(18).VBM(3C98).SAVH(18,18).HVBM(3C80),LV
BM(3C80).ERROUT
TblRdErr
NVC:Reconstructing
LBA(FFFFFE17).LEC(0).X(8).PG(9C22),SABNR(3B).VBM(3C98).SAVH(3B,3B).HVBM(3CBD),LV
BM(3CBD).ERROUT
TblRdErr
A solution for this problem without expensive DR-services would be much appreciated. :D
Some posts ago "book14" meant, that there are some tricks available to resolve this.
Thanks in advance for your help.
Chris
PostPosted: December 13th, 2011, 3:15
Hello!
I have the same problem. Can anybody help me? I can't find solution.
Thanks!
PostPosted: December 13th, 2011, 11:14
did you read this entire thread or no?
PostPosted: December 13th, 2011, 23:30
Merry Christmas!
The contents of NVC (Flash) damaged.
Medicine:
T>T9F
Begin Test 9F
ASCII logging on
Got to CertFlashBER_Clump
CallingInitNvcIo()
Calling M_ClearBadClumpList
Calling UnlockAllNvcBlocks
Calling FillBa ...
Data may be lost!!!
In the NVC is often MFT.
PostPosted: December 14th, 2011, 8:41
Thanks a lot, Tomset!
But I have:
Preamp ID 00 unsupported
F>
PostPosted: December 14th, 2011, 14:11
mostodont
This is far not the exact same problem.
The Preamp does not see.
Check the voltage at the Prеamp contacts.
Replace PCB.
