Discussions related to PC-3000
Please no pirated software here!
WD1600AAJS-00L7A Access problem
May 7th, 2012, 10:23
Hello!
I have a problem with a WD1600AAJS-00L7A. The drive identifies himself ok. Almost all modules are ok (except 2030, 2031, 2033...and others 20xx, but i have repaired). But I cannot access info. I get UNC error in all sector i test. I have already changed heads just in case, but i get the same error...I have tried hot pcb pasting the patient fw into the donnor using acelab method...same error...did anyone have this problem or have some test i can do?
Best regards and thanks in advance,
F.
Re: WD1600AAJS-00L7A Access problem
May 7th, 2012, 11:51
F_ARG wrote:Hello!
:dummy:
Why you tried that for drive with common FW issue? Who adviced you ?
Do you have pc3k ?
