Discussions related to PC-3000
Please no pirated software here!
June 13th, 2012, 5:08
I need loader for WD10EARS-00MVWB1 FW Vers: 00200076
The drive is from family Sadle G6
Heads number in use..................... : 4
Switched off heads...................... : Yes
Heads map............................... : 0,1,5,7
ROM Firmware version.................... : 00200076
Thank you in advance
June 13th, 2012, 5:43
are you sure about the HM?
June 13th, 2012, 6:06
HM Looks good to me for 1TB Sadle.
Dont have loader for this version, sorry
June 13th, 2012, 6:21
June 13th, 2012, 7:03
here is information in starting utility
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 256 Kb
ROM version............................. : 20.76E
ROM generation.......................... : 20.76E
Link table version...................... : 0B.3B.
Consolidated ROM version................ : 00200076
ROM Modules:
Flash ROM dir reading................... : Ok
Flash ROM dir (ext) reading............. : Ok (Active)
Modules directory address............... : 377 647 (24)
SA regions address...................... : by default
Heads configuration..................... : by map
Heads number............................ : 6
June 13th, 2012, 8:33
Could be refurbished.
Don't have that version either.
June 13th, 2012, 9:00
kimphonix wrote:Heads number............................ : 6
2TB models have head map of 0,1,2,5,6,7 - 6 heads.
June 13th, 2012, 12:12
hddguy wrote:kimphonix wrote:Heads number............................ : 6
As well as 1TB my friend.
I keep a record in my DB for such, and most of mine are 012567
June 13th, 2012, 14:06
Do not have that loader either.
Have a healthy WD10EARS-00MVWB0 drive with the following head map:
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 4
>Cyl Count............................... : 256
>Zone allocation table................... : Ok
>SA SPT.................................. : 1980
>ROM:
>ROM version............................. : 52.72B
>ROM generation.......................... : 52.72B
>Link table version...................... : 0A.1T.
>Consolidated ROM version................ : 00520072
>ROM Modules:
>Modules directory address............... : FIXED
>Heads map............................... : 1,5,6,7
>ROM Firmware version.................... : 00520072
>Service area:
>SA dir reading (ID)..................... : Ok
>SA Access............................... : Copy 0,Copy 1
June 13th, 2012, 14:30
labtech wrote:Do not have that loader either.
>Techno mode key
>RAM:
>ROM:
>ROM Modules:
>Service area:
WD10EARS-00MVWB0 the one u mentioned here HM: 1567 is it Sadle_G6 ?
and sure this is the default HM my dear? with this 771698 ?
thnx
June 13th, 2012, 15:02
Sadle G6 with default heads map. Default as in non-modified map, and not as in type of map.
PCB is 2060-771698-002 REV P1 - I guess this is what you were asking about einstein9, right?
June 14th, 2012, 3:43
Yes thats right
as an example here: >Heads map............................... : 1,5,6,7
i do not think this is the Def. HM, its been changed
as you see here:
its clear now for me, my DB records are always ACCURATE heeheh
June 14th, 2012, 8:27
This could be a trimmed down 1.5TB or 2.0TB model. It happens.
June 14th, 2012, 9:13
northwind wrote:>Heads number............................ : 6
All the time, I agree. Manufacturers don't waste platter space. Bummer for DR, though.
June 14th, 2012, 9:43
>Techno mode key
>RAM:
>ROM:
>ROM generation.......................... : 20.77E
>ROM Modules:
>Heads map............................... : 0,1,2,5
>Service area:
>SA dir reading.......................... : Ok
> Mod 11 attached
- Attachments
- 11.rar
- (330.13 KiB) Downloaded 456 times
June 14th, 2012, 21:57
Thank you everybody for your information.
Thank you pcimage for your LDR. I will try to use this.
June 19th, 2012, 5:06
pcimage please, for this issue I need module#32 with same F/W like this module#11.
Could you please give me?
Thank you in advance.
