 Post subject: WD10TPVT-00U4RT1, heads working on Donor, but not in the nat
PostPosted: July 2nd, 2012, 6:25
I have Western Digital-SATA 2.5-
WD10TPVT-00U4RT1-
1000 GB
It was clicking then stops from spinning, I changed the heads from New Donor to the damaged drive, it did not work, same behavior.
Now I put the native heads (that was originally in the damaged drive) into donor drive, it worked properly. Strange.
I need Loader, may be it can solve the problem, because it is not head problem.
Model: WD10TPVT-00U4RT1
Rom Info:
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 256 Kb
ROM version............................. : 08.06B
ROM generation.......................... : 08.06B
Link table version...................... : 02.07.
Consolidated ROM version................ : 00080006
If any idea please help.
Thank you
 Post subject: Re: WD10TPVT-00U4RT1, heads working on Donor, but not in the
PostPosted: July 2nd, 2012, 6:30
Its Family is Helios
PostPosted: July 6th, 2012, 6:05
Will hotswap allow SA access?
PostPosted: July 6th, 2012, 9:39
LDR wont help you. You should prevent SA access then check if spindle still stops. Maybe some surface has an error also.
Donor heads work back in donor HDD, what did donor do with patient heads? Did you test this?
Users browsing this forum: No registered users and 132 guests
