June 26th, 2012, 6:44
Hi Guys,
Looking for a loader for the above drive, bit of an oddball I know.......but if anyone can help, I'd really appreciate it...
F/W HPG0
Many thanks.....
Steve...
June 27th, 2012, 7:43
Hi Steve,
You didn't say which version you needed.
Try this one...
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>Zone allocation table................... : Ok
>Cyl Count............................... : 170
>SA SPT.................................. : 1311
>Head number reading..................... : Ok
>Heads number............................ : 1
>ROM:
>Flash Dir reading....................... : Ok
>ROM reading............................. : Ok
>ROM Data size........................... : 192 Kb
>ROM version............................. : 05.8VD
>ROM generation.......................... : 05.92D
>Link table version...................... : 04.AH.
>Heads configuration..................... : by map
>Heads number in use..................... : 1
>Switched off heads...................... : No
>Head map................................ : 0
>ROM Firmware version.................... : 0005008V
>Service area:
>SA dir reading.......................... : Ok
>SA Copies avalabled..................... : Copy 0
>Configuration reading................... : Ok
>Master Password......................... : has not been set
>User Password........................... : has not been set
!SA Firmware version..................... : 00050092
- Attachments
- 11.rar
- (323.8 KiB) Downloaded 483 times
September 25th, 2012, 10:21
Touchclarity, Did you finish this case ? I got one of these today.....
