 Post subject: LDR WD6400BEVT - 22A0RT0 | Mariner
PostPosted: October 18th, 2012, 4:47
Hi Guys,
i need the loader for Hd: WD6400BEVT - 22A0RT0
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 256 Kb
ROM version............................. : 14.1AL
ROM generation.......................... : 14.1AL
Link table version...................... : 05.0D.
Consolidated ROM version................ : 0014001A
ROM Modules:
Flash ROM dir reading................... : Ok
Modules directory address............... : FIXED
SA regions address...................... : by default
Heads configuration..................... : by map
Heads number............................ : 4
Heads number in use..................... : 4
Switched off heads...................... : No
Heads map............................... : 0,1,2,3
ROM Firmware version.................... : 0014001A
Thanks in advance
 Post subject: Re: LDR WD6400BEVT - 22A0RT0 | Mariner
PostPosted: October 18th, 2012, 9:05
good luck :)
11.rar [165.86 KiB]
Downloaded 510 times
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: October 18th, 2012, 9:31
So fast!!! Thank you very much! :mrgreen:
