 Post subject: SEAGATE HEAD CHANGE
PostPosted: March 4th, 2009, 9:16
Hi to all,
Afther change heads in the disk i have this.
PCB is from donor
HEADS from donor
Reset
4096k x 16 DRAM
GALAXY2D - 1_Disk    S-6A   05-31-06 13:44
Head Mask FFFF - Switch to full int.
              Spin Ready
ERR Read App Code
F>
Platter have this:
Ze
ZeBong
" Россия еще раз"
 Post subject: Re: SEAGATE HEAD CHANGE
PostPosted: March 4th, 2009, 11:25
What are the drive models? PN ? FW? Country ?
If original pcb is ok always use that.
Best regards,
Dobre
Murphy was an optimist
PostPosted: March 4th, 2009, 11:35
Hi Dobre,
The original PCB is OFF :(
Flash Rom Erased
Ze
ZeBong
" Россия еще раз"
PostPosted: March 4th, 2009, 14:42
Zebong,
You should perform terminal command
F>R4
And then paste here result (A3 or A6?)
A3: App code damaged (BAD's in SA)
A6: Incompatible App code (PCB is incompatible)
If A6 - change PCB and see;
If A3 - you should find compatible Loader (same Eng Rev with patient) and load only App code.
Then F>j.
But don't write to SA anything (App code for example).
This user was found to be affiliated with Ace Lab/PC-3000. See this topic for details.
PostPosted: March 5th, 2009, 8:35
Thanks Creator,
Have this in terminal.
Reset
4096k x 16 DRAM
Buzz  - Head Mask FFFF - Switch to full int.
              Spin Ready
ERR Read App Code
F>R4
    Code - FF  Track 15A76.0.022  Sns 022
F>
ZeBong
" Россия еще раз"
PostPosted: March 5th, 2009, 10:36
zebong wrote:
Thanks Creator,
Reset
4096k x 16 DRAM
              Spin Ready
ERR Read App Code
F>R4
F>
FF - Unsupported preamp? :shock:
PostPosted: March 6th, 2009, 3:05
FF=Unsupported code in the new preamp interface....Looks like incompatible heads.
Rgds
www.datasave.ro
PostPosted: March 6th, 2009, 14:53
Hi ccc,
Look at my patient / donor :
What do you think is possible to have different preamp ?
ZeBong
ZeBong
" Россия еще раз"
PostPosted: March 6th, 2009, 21:20
start a loader and see what happen..
maybe we can discuss OL
See My PM
Спасибо
СУТИОНО / АПИНГ
PostPosted: March 13th, 2009, 1:31
check the preamp ic-chip and see if its matches with the other one
it looks to use that its using a diffrent type ic
dirty tricks of seagate to stop us recovering hard drives :(
PostPosted: February 4th, 2013, 18:47
hi , How do you do the scratches on your disc surface
used during the head is broken
PostPosted: February 4th, 2013, 18:55
hi dear friends you can turn head tool
PostPosted: February 8th, 2013, 20:26
hi, data recovery device for scratched surface
could you give information
