 Post subject: WDC WD20EARX-00PASB0 module 00 needed, please.
PostPosted: January 10th, 2013, 17:50
Module 00 is broken.
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 6
Cyl Count............................... : 256
Zone allocation table................... : Ok
SA SPT.................................. : 1980
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 256 Kb
ROM version............................. : 20.88E
ROM generation.......................... : 20.89E
Link table version...................... : 0B.3F.
Consolidated ROM version................ : 00200088
ROM Modules:
Flash ROM dir reading................... : Ok (Active)
Modules directory address............... : 108 041 (24)
SA Translator loading................... : Ok
Heads configuration..................... : by map
Heads number in use..................... : 6
Switched off heads...................... : No
Heads map............................... : 0,1,2,5,6,7
ROM Firmware version.................... : 00200088
Module 2E............................... : Header error
Module 6F............................... : Checksum error
Module 00............................... : Critical header error
 Post subject: Re: WDC WD20EARX-00PASB0 module 00 needed, please.
PostPosted: January 10th, 2013, 20:34
Banned User
I have this drive, but i'm not a DR, i do not have tools like pc3k or hd doctor..
I have Sediv demo version but i thing i'm not able to help you, sorry.
PostPosted: January 11th, 2013, 5:28
Tackar Friedrich i alla fall. Jag har hittat annan lösningen.
PostPosted: January 11th, 2013, 5:29
No need for module anymore, the solution was head map editing.
PostPosted: January 11th, 2013, 10:33
Banned User
Which tool have you use for head map?
PostPosted: January 12th, 2013, 0:58
I don't want to give an expression to be a wise guy but as this forum is for PC3K, I am using it.
PostPosted: March 24th, 2013, 19:49
HAve you a rom version 00200088?
PostPosted: March 27th, 2013, 8:26
Here you have.
ROM.zip [227.11 KiB]
Downloaded 429 times
ACELab partner
