 Post subject: Problem with new Deepspar Imager
PostPosted: May 4th, 2013, 21:47
So, not really a PC3K question but this section is the closest applicable I could find to post in.
I boot with the flash drive and type "ddi", and computer just restarts.
Have the network add-on card which is detected during boot.
This happens with or without drives attached. Power is connected correctly to DDI card; power indicator LED on board stays green.
The PC I installed the DDI in works perfectly. Has Windows 7 x64, but I assume that doesn't matter as DDI doesn't make use of the hard drive in the PC (or am I wrong?).
I haven't been set up on the Deepstar forum yet or I'd have posted there and it's the weekend so I don't expect my e-mail inquiry to be answered by the team until next week.
Just would like to work with it this weekend and was wondering if anybody has run into this problem or has any tips.
Sam
 Post subject: Re: Problem with new Deepspar Imager
PostPosted: May 5th, 2013, 2:17
HI
check your Computer Mother Board (Main Board) Deepspar Prefers some specific Boards with Nvidea Chipset Hope it helps Good Luck....
PostPosted: May 5th, 2013, 3:08
microsoftengineer wrote:
HI
+20
In Addition, you Better ask their support for such cases
I guess MAYBE some wrong cable connection there
PostPosted: May 6th, 2013, 11:55
Update:
Serge suggested disabling all peripherals/on-board devices and changing to IDE. None of these worked.
Works fine on a different computer.
Users browsing this forum: No registered users and 14 guests
