 Post subject: HD103SJ ROM ver 1AJ10002
PostPosted: January 14th, 2014, 12:22
Does anybody have a ROM for this ver, please?
 Post subject: Re: HD103SJ ROM ver 1AJ10002
PostPosted: January 14th, 2014, 14:50
Sure its 1AJxxx or 1AGxxx?
double chk :wink:
PostPosted: January 14th, 2014, 14:56
chk this
SAMSUNG HD103SJ.rar [1.48 MiB]
Downloaded 753 times
PostPosted: January 14th, 2014, 15:36
Thanks, have plenty of that version.
See pic, please.
PostPosted: January 14th, 2014, 17:32
If you just need the ROM, it turned up as the second hit in a Google search. :-)
Samsung F3 250GB 7200 3.5" SATA2 HDD, F3 500GB 7200 3.5" SATA2 HDD, F3 750GB 7200 3.5" SATA2 HDD, F3 1TB 7200 3.5" SATA2 HDD, v.1AJ10002, A00:
http://downloads.dell.com/SATA/F3_Patch.zip
http://www.dell.com/support/drivers/us/ ... id=R306059
Firmware for Samsung F3 250/500/750/1TB SATA2 HDD Release Date: 6/16/2011
Importance: Urgent
Version: 1AJ10002,A00
Extract the EXE file and carve the HD103SJ ROM code out of it.
If you need help in doing this, then see this thread:
http://www.tomshardware.com/forum/26978 ... j-firmware
PostPosted: January 14th, 2014, 21:03
I should add that the ROM code in the firmware update only covers the first half of the ROM. The second half is filled with 0xFF bytes except for a small FIPS section at offset 0x70000 (IIRC). The FIPS data sometimes become corrupted, resulting in a no-spin symptom. You can sometimes (always?) patch FIPS data from a donor ROM, but from what I have read at Ace Labs' forum, you should be able to substitute a dummy FIPS consisting of 16 header bytes and two checksum bytes at the end. The 16-bit little endian checksum is computed such that the overall sum of the FIPS block is 0x0000. I can do this for you if you like.
BTW, the firmware update also includes an update for the MOVLY001 module.
Here is my Analysis of Samsung's SpinPoint F3 firmware update:
http://malthus.zapto.org/viewtopic.php? ... 1986#p1986
Here is the structure of the firmware image file:
http://malthus.zapto.org/viewtopic.php? ... 1989#p1989
PostPosted: January 15th, 2014, 5:43
See pic, please.
yes, i can see that, when i 1st. looked i thought its SI not SJ
my mistake :>
:wink:
PostPosted: January 15th, 2014, 7:50
einstein9 wrote:
See pic, please.
my mistake :>
:wink:
NP.
Thanks Frank. I was looking for something quicker. Will see.
PostPosted: January 15th, 2014, 10:26
Here you are
1AJ33suM_d26.rar [169.89 KiB]
Downloaded 621 times
PostPosted: January 15th, 2014, 11:57
labtech wrote:
einstein9 wrote:
See pic, please.
my mistake :>
:wink:
NP.
It only took me 10 minutes. :? The FIPS section is a dummy, though. I've also included the MOVLY001 module.
BTW, you can use the same technique for other drives. Here is a Seagate example:
Tip: Locating ROM and SA resources in firmware updates:
http://malthus.zapto.org/viewtopic.php? ... 705&p=2196
HD103SJ_1AJ1002_F3_Patch.zip [238.91 KiB]
Downloaded 605 times
PostPosted: January 15th, 2014, 12:22
Here's ROM and full resources...
http://files.hddguru.com/index.php?acti ... AMSUNG/F3&
PostPosted: January 16th, 2014, 8:32
Thank you very much for the ROMs. Worked. Imaging...
