Discussions related to PC-3000
Please no pirated software here!
Seagate PCB 100645422 Short Points
January 16th, 2013, 12:36
Does anyone know the short-out point for this board
Model number ST2000DM001
The ace manuals do not have that one listed yet.
I attached a zip of the front and back of the board.
100645422.zip
(777.38 KiB) Downloaded 1108 times
Re: Seagate PCB 100645422 Short Points
January 16th, 2013, 12:42
ACE TS does not know?
January 16th, 2013, 12:48
labtech wrote:ACE TS does not know?
I asked on the forums already, just their response is never great, so I thought i would ask here as well.
January 16th, 2013, 15:31
ACE forums are useless for tech support. You pretty much need to contact them via Skype in order to get a straight answer.
January 16th, 2013, 16:50
lcoughey wrote:ACE forums are useless for tech support. You pretty much need to contact them via Skype in order to get a straight answer.
I will try in the morning if there is no response by then.
January 18th, 2013, 7:17
Cleanroom wrote:Does anyone know the short-out point for this board
PM Sent.. :wink:
February 23rd, 2013, 13:32
Hi,buddy ,same question .could u send me a PM about short-out point on that PCB?really appreciate !
February 28th, 2013, 11:54
I know this, but I do not want to overt, if you need to, you can give me an E-mail and I will tell you the method!
polanwu@163.com
November 11th, 2013, 16:53
Can I have a PM with those shorting point and method, please? Or maybe an e-mail: bucovina_bloodhand@hotmail.com
Thanks!
November 12th, 2013, 3:17
If you mean the read channel, see the following:
Tip: How to identify the Read Channel test points:
http://malthus.zapto.org/viewtopic.php? ... 123&p=1632
April 27th, 2014, 11:25
Hello
could someone help me? I ve spent times trying toi get the CTRL Z working, and it seems that I need to find and short the read channel. But I have no idea where it is on the board. An image with the exact points should be great.
Cheers (ST2000MD001)
July 16th, 2014, 19:13
billyk1 wrote:Hello
Here good luck
