Discussions related to PC-3000
Please no pirated software here!
pcb compatible?
September 28th, 2014, 12:14
HI GUrus,
is PCB 2060-771824-008 REv P1 WD5000AZRX-00A8LB0(This is faulty PCB)
& PCB 2060-771824-003 Rev A WD30EZRX-00DC0B0 COMPATIBLE ?
Can i use PCB 2060-771824-003 Rev A WD30EZRX-00DC0B0 as donor for PCB 2060-771824-008 REv P1 WD5000AZRX-00A8LB0 as donor?
Thanks in advance
attachments.zip
(8.92 MiB) Downloaded 4600 times
WD5000AZRX / WD30EZRX pcb compatible?
September 30th, 2014, 13:59
DRCP wrote:Can i use PCB 2060-771824-003 Rev A WD30EZRX-00DC0B0 as donor for PCB 2060-771824-008 REv P1 WD5000AZRX-00A8LB0 as donor?
Yes, if MCU tagging, PCB tagging and PCB revision are the same.
