November 26th, 2014, 10:52
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 256 Kb
ROM version............................. : 03.52C
ROM generation.......................... : 03.53B
Link table version...................... : TP.46.
Consolidated ROM version................ : 00030052
ROM Modules:
Flash ROM dir reading................... : Ok (Active)
Flash ROM dir reading (Ext)............. : Ok
Modules directory address............... : 70 867
SA regions address...................... : by default
SA Translator loading................... : Ok
SA defects assigned..................... : 14
Heads configuration..................... : by map
Heads number............................ : 4
Heads number in use..................... : 4
Switched off heads...................... : No
Heads map............................... : 0,1,2,3
ROM Firmware version.................... : 00030052
Thanks!!
November 26th, 2014, 11:02
here is complete FW+ROM
good luck
- Attachments
- WDC WD10JMVW-11S5XS0 01.01A01 WD-WX81A7243796.zip
- (13.6 MiB) Downloaded 748 times
November 26th, 2014, 15:16
Thanks!!
I got the mod 11 already and drive cloning now
