Discussions related to PC-3000
Please no pirated software here!
FBLite Ldr required
December 9th, 2014, 12:09
WD10JMVW-11AJGS2
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 4
Cyl Count............................... : 256
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 256 Kb
ROM version............................. : 16.1VH
ROM generation.......................... : 16.1VH
Link table version...................... : NA.31.
Consolidated ROM version................ : 0016001V
ROM Modules:
Flash ROM dir reading................... : Ok (Active)
Flash ROM dir reading (Ext)............. : Ok
Modules directory address............... : 110 006
SA regions address...................... : by default
SA Translator loading................... : Ok
Heads configuration..................... : by map
Heads number in use..................... : 4
Switched off heads...................... : No
Heads map............................... : 0,1,2,3
ROM Firmware version.................... : 0016001V
Thanks!
Re: FBLite Ldr required
December 9th, 2014, 13:23
This is for C version.
Want to try?
11.rpm.zip
(468.96 KiB) Downloaded 500 times
December 9th, 2014, 13:27
sorry i have 00160014 . 00160015 . 0016001C
December 9th, 2014, 13:33
http://files.hddguru.com/index.php?acti ... rd%20Lite&
December 10th, 2014, 8:05
Thanks!
Worked fine, drive working now :-)
December 10th, 2014, 8:45
Nice, another happy customer and $$ in the pocket
December 10th, 2014, 15:40
Still plenty to do on the case, mind you.
Drive was dropped whilst running and so has media damage. :-(
December 10th, 2014, 15:56
Never easy, right?!?
Media damage fighting is so tiring..
