Discussions related to PC-3000
Please no pirated software here!
Looking a loader to WD3200BEVT
December 18th, 2014, 13:02
Hi gurus,
I'm looking a loader to WD3200BEVT-60ZCT1 Denali.
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 4
Cyl Count............................... : 128
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 192 Kb
ROM version............................. : 08.30D
ROM generation.......................... : 08.30D
Link table version...................... : 02.14.
Consolidated ROM version................ : 00080030
ROM Modules:
Flash ROM dir reading................... : Ok
SA regions address...................... : by default
SA Translator loading................... : Ok
SA defects assigned..................... : 8
Heads configuration..................... : by map
Heads number in use..................... : 4
Switched off heads...................... : No
Heads map............................... : 0,1,2,3
ROM Firmware version.................... : 00080030
Thank you all for your time and support!
Re: Looking a loader to WD3200BEVT
December 18th, 2014, 14:03
>Techno mode key
>RAM:
>Zone allocation table................... : Ok
>SA SPT.................................. : 693
>ROM:
>ROM version............................. : 08.31D
>ROM generation.......................... : 08.31D
>Consolidated ROM version................ : 00080031
>ROM Modules:
>ROM Firmware version.................... : 00080031
>Service area:
>Permanent overlay....................... : Loaded
>SA dir reading (ID)..................... : Ok
>SA Access............................... : Copy 0,Copy 1
Hello. Is this going to help you ? slight difference
December 19th, 2014, 4:50
Here's Version 00080030 from an 80Gb drive, should work....
11.rar
(159.89 KiB) Downloaded 522 times
December 19th, 2014, 14:52
Thank you all, public and private messages were helpful. This one turned out to be bad head(s) though.
