 Post subject: Need loader WD3200LPVX-75V0TT
PostPosted: May 21st, 2015, 8:47
I need loader for WD3200LPVX-75V0TT.
Rom: 06.1AJ.
Best Regards
 Post subject: Re: Need loader WD3200LPVX-75V0TT
PostPosted: May 21st, 2015, 11:55
Here you are...
Mikippp
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 2
>Cyl Count............................... : 256
>Zone allocation table................... : Ok
>SA SPT.................................. : 1437
>ROM:
>ROM reading............................. : Ok
>ROM Data size........................... : 256 Kb
>ROM version............................. : 06.1AJ
>ROM generation.......................... : 06.1BJ
>Link table version...................... : NB.11.
>Consolidated ROM version................ : 0006001A
>ROM Modules:
>Flash ROM dir reading................... : Ok
>Flash ROM dir reading (Ext)............. : Ok (Active)
>Modules directory address............... : 103 543
>SA regions address...................... : by default
>SA Translator loading................... : Ok
>Heads configuration..................... : by map
>Heads number in use..................... : 2
>Switched off heads...................... : No
>Heads map............................... : 0,1
>ROM Firmware version.................... : 0006001A
>Service area:
>Permanent overlay....................... : Loaded
>SA dir reading (ID)..................... : Ok
>SA Access............................... : Copy 0,Copy 1
11.zip [470.93 KiB]
Downloaded 546 times
PostPosted: May 22nd, 2015, 5:44
Thanks a lot for your help, it's perfect.
Users browsing this forum: No registered users and 14 guests
