 Post subject: [help]Need the firmware WD5000BMVW-AMCS4
PostPosted: July 2nd, 2015, 20:51
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 3
>Cyl Count............................... : 256
>ROM:
>ROM reading............................. : Ok
>ROM Data size........................... : 256 Kb
>ROM version............................. : 55.03B
>ROM generation.......................... : 55.03B
>Link table version...................... : 05.03.
>Consolidated ROM version................ : 00550003
>ROM Modules:
>Flash ROM dir reading................... : Ok
>SA regions address...................... : by default
>SA Translator loading................... : Ok
>Heads configuration..................... : by map
>Heads number in use..................... : 3
>Switched off heads...................... : No
>Heads map............................... : 1,2,3
>ROM Firmware version.................... : 00550003
 Post subject: Re: [help]Need the firmware WD5000BMVW-AMCS4
PostPosted: July 2nd, 2015, 23:15
It's been in the files section for over a year...
PostPosted: July 4th, 2015, 3:22
Give me the address of it, thank you
