 Post subject: WD10001FALS LDR and modules
PostPosted: September 9th, 2015, 8:54
Hello Folks, i need resources for this model. Thank you.
Model: WD1001FALS-403AA0
Family: Tahoe 2D
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 4
Cyl Count............................... : 256
Zone allocation table................... : HDDs RAM reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 512 Kb
Flash ROM dir reading................... : Ok
Flash ROM dir reading (Ext)............. : Ok (Active)
Modules directory address............... : 246 286
SA regions address...................... : by default
SA Translator loading................... : Ok
SA defects assigned..................... : 1
ROM Modules:
ROM version............................. : 00.70B
ROM F/W version......................... : 00000070
Overlay F/W version..................... : 00.70B
Servo F/W version....................... : 02.0W
Heads configuration..................... : by map
Heads number in use..................... : 4
Switched off heads...................... : No
Heads map............................... : 0,1,2,3
Service area:
Permanent overlay....................... : Not loaded
SA dir reading (ID)..................... : SERVO ERROR CODE BASE SvirActSync
SA SPT Detect........................... : FAIL
SA dir reading (ABA/CHS)................ : Module reading error: ABA 578 062(1) reading error Physical read error C/H/S: 236/1/287 Device Error Detected: "VSC ERR KEY SECTOR MUST PRECEED DATA XFER REQUEST"
SA Access............................... : NONE
Configuration reading................... : Module 02 not found
 Post subject: Re: WD10001FALS LDR and modules
PostPosted: September 9th, 2015, 14:48
http://files.hddguru.com/index.php?acti ... ahoe%202D&
PostPosted: September 10th, 2015, 8:56
try to load the resource and the LDR and Hot Swap , But I think its Head Problem 80%
Users browsing this forum: No registered users and 17 guests
