 Post subject: Shorting Point
PostPosted: October 16th, 2015, 2:23
Can anyone guide me for shorting point of 100717520 Rev B.
Pic of PCB attached
Thanks in advance
 Post subject: Re: Shorting Point
PostPosted: October 16th, 2015, 3:11
15+16 or 17+18
PostPosted: October 16th, 2015, 3:12
contacts 16-18 on J4
odd the top row, the lower even
PostPosted: October 16th, 2015, 12:11
17+18 Worked but with following error
Boot 0x40M
Spin Up[LBA=0x000042F9]N02020C20o0o0o0o0o0o0o0o0[LBA=0x000042F9]NO1111[LBA=0x00066E3B]N01010C20o0o0o0o0o0o0o0o0[LBA=0x00066E3B]NO1111[LBA=0x00028F1D]N01020C10o0o0o0o0o0o0o0o0[LBA=0x00028F1D]NO1111[LBA=0x0008BA5F]N01010C10o0o0o0o0o0o0o0o0[LBA=0x0008BA5F]NO1111
SimError - Remaining in BootFW
Perform a double download without a power cycle
Terminal output at power on
Boot 0x40M
PostPosted: October 17th, 2015, 6:58
You are shorting the drive to early it's all about timing with the Seagate DM drives.
By the way what's the problem with the drive?
Web: https://www.day1data.de
PostPosted: October 18th, 2015, 4:50
HDD remains in bsy state.
No buzz/no clicking/motor not spin down.
At power on remains busy & terminal output is
Boot 0x40M
Spin Up
Trans.
Spin Up
SpinOK
SnapshotEventOccurred( SNAPSHOT_INITIAL_VALUES ).
(P) SATA Reset
Tried motor isolation method but not worked.
In short circuit method give following output (HDD goes in ready state)
Boot 0x40M
Spin Up[LBA=0x000042F9]N01020C10o0o0o0o0o0o0o0o0[LBA=0x000042F9]NO1111[LBA=0x00066E3B]N01010C10o0o0o0o0o0o0o0o0[LBA=0x00066E3B]NO1111[LBA=0x00028F1D]N01020C10o0o0o0o0o0o0o0o0[LBA=0x00028F1D]NO1111[LBA=0x0008BA5F]N01010C20o0o0o0o0o0o0o0o0[LBA=0x0008BA5F]NO1111
and after that if i restart utility without re-power it detects
Model : ST2000DM001
Firmware : SC48
Capacity : 3.86 GB (8 089 950)
PostPosted: October 18th, 2015, 7:10
So now I'd go in, edit module 93 to disable all the auto reallocation and idle activities so it'll start up normally going forward. Then try to figure out why it's not showing correct capacity, maybe it will after power cycle.
PostPosted: October 26th, 2015, 12:11
Hello
Need Loader for this HDD ST2000DM001 FW SC48
Can anyone have?
Thanks in advance
PostPosted: October 28th, 2015, 19:35
Before trying loader, see if you can read system files through terminal and see if any critical ones are damaged.
PostPosted: October 29th, 2015, 9:50
Jared ,
Sir I Saw a Few Posts of Spildit Where He Says That any Times We Have To Set These Settings Back To Default State .In My Case i Follow the Procedure As You stated .Right Now i am working on a ST3500620AS Moose Family With Dell DE12 Firmware [ Thats Buggy ] But My Drive Cloned Well Only 6203 Not readable Sectors And Approx 57201 Skipped Sectors That i Am Still Working On Slowly On PC3K
PostPosted: October 29th, 2015, 11:31
hello,
i am not able to read any of system files.
PostPosted: October 29th, 2015, 13:56
DRCP wrote:
hello,
Well,
Please Let Us Know What All Tools You Have So That Suggestions Pour In
