Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
 Post subject: Re: Kind ROM request WD10EADS-22M2B0 board 2061-701640-700 0
PostPosted: March 14th, 2016, 2:39
Would you attempt to replace the SMOOTH ic?
We have the tools and the experience to do that but again without schematics, the worry is to burn it because of other possibly damaged components.
PostPosted: March 14th, 2016, 15:45
I would measure the resistance (on the 200 ohms range) between ground, +5V and each of Vio and Vcore. This will tell you whether the MCU or Q2 are shorted. Also check the zero-ohm resistors in that area, eg R46.
If there are no shorts, then I would be willing to try a SMOOTH replacement.
Users browsing this forum: No registered users and 17 guests
