 Post subject: WD20EARX-00ZUDB0
PostPosted: April 7th, 2016, 13:40
I have a problem with this hdd type, no longer recognizes ID .
Can anyone help me with his repair .
I have PC 3000 interface, WDC, Marwell, etc maybe with team viewer.
Thank you in advance.
 Post subject: Re: WD20EARX-00ZUDB0
PostPosted: April 7th, 2016, 14:41
Try contact ace support directly.
ACELab partner
PostPosted: April 8th, 2016, 8:13
I have the interface only in weekend
PostPosted: April 8th, 2016, 8:42
not enough info to go on
does it spin up ?
if so, does it make any unusual noise (clicking, beeping Etc.) ?
if NOT, does it stays spinning ?
What LEDs do you get in PC3K ? (Bsy? )
PostPosted: April 8th, 2016, 9:45
Did it read the ID correctly while in your possession?
PostPosted: April 11th, 2016, 14:03
Yes, it work ok but i modify sectors and I need ROM and LDR file for this model Draco fammily to restore original size
PostPosted: April 11th, 2016, 15:06
What do you mean original size ? you played with HPA ?
anyway, the size of 2TB = 3,907,029,168 sectors
PostPosted: April 11th, 2016, 16:10
HddHackr?
PostPosted: April 11th, 2016, 17:00
No HddHackr...only my stupid brain...
I do not care data stored on it, I just want to recover the structure of ROM, because I changed the name and I played with size and name before to save the ROM. I need someone to tell me how and what to read/write to recover original ROM.
And yes I played with HPA
PostPosted: April 11th, 2016, 17:09
Depending on the state of the drive, you can remove the HPA using HDAT2, MHDD, etc, or you could restore MOD 02 from a copy (MOD 802F or 802E).
The ROM stores various ID info in MOD 0D.
PostPosted: April 11th, 2016, 18:09
Since you have PC3000, you can restore max LBA with it easily, 2-3 clicks.
As far as the ROM, there are several options per suggestions already made and can also attempt to recreate. Can read PC3000 manual.
Users browsing this forum: No registered users and 90 guests
