 Post subject: LDR for WD3200BPVT-22JJ5T0 - 0065007M
PostPosted: May 12th, 2016, 11:45
Found a lot of loaders in forum, but all mean Not compatible?
SA Dir reading OK, but no Overlay...
 Post subject: Re: LDR for WD3200BPVT-22JJ5T0 - 0065007M
PostPosted: May 12th, 2016, 13:33
Module 11 only varies by drive family and ROM revision. If you've matched that, you have the right ldr. You probably have other issues such as bad heads. Also you should note that on some models you need to disable SA access when doing LDR upload or it'll automatically start reading the SA and hang.
Or are you saying that you can't find the one for that ROM revision?
PostPosted: May 13th, 2016, 2:51
OK, that's my first tip... i ordered a disk already ;)
PostPosted: May 19th, 2016, 12:22
also with new heads i'm not able to read out, because small ditches on surface.
does anyone has this Loader?
PostPosted: June 2nd, 2016, 18:48
So for all people out there searching for this loader and all other modules ;)
i got the disk running, and most modules are in there
WDC WD3200BPVT-22JJ5T0-65007M.zip [9.45 MiB]
Downloaded 568 times
