 Post subject: Seagate Arch ST10. Understanding of [CTRL] +[L] output
PostPosted: September 5th, 2016, 0:59
Hello evryone,
kindly seek for your help in understanind of the [CTRL] +[L] command output, after i run i have following data:
T>NHAWK2HD - 1_Disk 4.ADA 12-04-07 17:00 ADA,NH_1D_2H_S,14
Built for NHAWK2HD,PITKIN,Redback,TI1843 PreAmp,Agere7539 PreAmp,McKinleyLite,1Disk,220 Servos,7200RPM,8Pole,133MHz,RwFeat=0002,VBAR
my questions are following:
1. What is NHAWK2HD,PITKIN,Redback ?
2. TI1843 PreAmp - is it preamp model or revision or anything else ?
3. Agere7539 PreAmp - is it preamp model or revision or anything else ?
4. McKinleyLite - what is this ?
5. 220 Servos - what is this mean ?
6. 133MHz - is it Preamp freq. or proc. ?
7. What is RwFeat=0002 ?
8. What is VBAR ?
and the last q. : is which are parameters from the output are critical in donor search process ?
Thank you in advance,
regards Max.
 Post subject: Re: Seagate Arch ST10. Understanding of [CTRL] +[L] output
PostPosted: September 8th, 2016, 6:19
Bump, as I would like to know as well
PostPosted: September 8th, 2016, 16:29
VBAR = Variable Bit Aspect Ratio
TI1843 PreAmp / Agere7539 PreAmp - preamp part numbers made by Texas Instruments (TI) and Agere
NHAWK2HD - Seagate's internal name for the drive family
Users browsing this forum: No registered users and 111 guests
