 Post subject: ST1000DM003 showing 32 MB only running smoothly no sound
PostPosted: October 11th, 2016, 2:34
I have Seagate ST1000DM003 hdd showing 32 MB size only .....running smoothly no sound
terminal shows following details when we power on the hdd :-
Boot 0x40M
Spin Up[0x000065B4][0x00006A20][0x00006E8C]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
(P) SATA Reset
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MC Seg Disc and Cache Nodes: 40125B28 40122F00
Seg Write Preamble VBM start: 0000204A end: 00002091
Footer - start: 00002093 end: 000020DA
Seg Read Preamble VBM - start: 000020DC end: 00002123
Footer - start: 00002125 end: 0000216C
Reconstruction: MCMT Reconstruction Start
Max number of MC segments 0A61
Nonvolatile MCMT sequence number 010AA616
[RSRS] 03C6
Reconstruction: Completed 0: HeadPtr was unwritten
[MCMTWS]
MCMainPOR: MCTBufferPtr->Header.MCStateFlagsDisc = 00000041
MCMainPOR: MCTBufferPtr->Header.MCTStateFlags = 0000002A
MCMainPOR: MCStateFlags = 00000041
MCMainPOR: Feature Enabled...
PowerState = IDLE1
PowerState = IDLE2
Any help appreciated
 Post subject: Re: ST1000DM003 showing 32 MB only running smoothly no sound
PostPosted: October 17th, 2016, 8:20
Hello!
Do you have terminal access ?
PostPosted: October 17th, 2016, 10:03
Boot 0x40M
Trans.
Rst 0x40M
Spin Up
(P) SATA Reset
MCMainPOR: Start:
[RSRS] 03C6
[MCMTWS]
PowerState = IDLE1
PowerState = IDLE2
Well,
Are You Interested To Work With a Lab Thats Good With Physical HDD Work .If Yes You Can Count Me In .I am Aware That You Were Outsourcing Some Physical Cases To a Company And i Can Do a Much Better Job For Those .As Far As This Job Is Concerned We Can Try Firmware Manupulation By Blocking Access Initially And If it works then no issue ,Otherwise We Can Change Your Heads .
PS : If You Have Started To Do Physically Work Yourself Let Me Know So That i can help you with some techniques Etc
PostPosted: October 17th, 2016, 13:04
viewtopic.php?f=1&t=34309&p=239443#p239443
GigaByte BIOS bug results in loss of 1TB capacity:
http://www.hddoracle.com/viewtopic.php?f=59&t=150&p=275
