Discussions related to PC-3000
Please no pirated software here!
Loader for WD30NMVW-11C3NS2
July 12th, 2016, 7:17
Hi ,
I required loader for WD30NMVW-11C3NS2 , if someone has then please share.
Ron
Re: Loader for WD30NMVW-11C3NS2
July 12th, 2016, 9:17
What version?
July 12th, 2016, 9:34
ROM version............................. : 01.24C
ROM F/W version......................... : 00010024
October 28th, 2016, 2:38
Hello friends
I'm in a similar situation
need the loader for the same drive WD30NMVW-11C3NS2, no one of you have saved these resources? Thank you for any
family on PC-3000 6.2 is reported as PebbleB
ROM Modules:
ROM version............................. : 01.32C
Overlay F/W version..................... : 01.32C
Servo F/W version....................... : D3.08
October 28th, 2016, 6:19
I have two to choose from
Mikippp
>ROM Modules:
>Overlay F/W version..................... : 01.25C
>Servo F/W version....................... : 03.08
>ROM:
>ROM reading............................. : Ok
>ROM Data size........................... : 512 Kb
>ROM generation.......................... : 01.33C
>Link table version...................... : D3.08.
>Consolidated ROM version................ : 00010032
11.zip
(549.37 KiB) Downloaded 831 times
11.zip
(549.23 KiB) Downloaded 801 times
October 28th, 2016, 8:36
Thank you so much!
My one is 24
October 29th, 2016, 0:38
Both of you have the same version rom code ,You both should try the loader given by miki But remember its not always the 11 no module sometimes we have to load other loaders also like 5c and 13 ,depends on family ,Might be a person can tryout loading loader on pebble series hdd and see what pc3k loads as it supports this family in version 6.2 .My lab has never encountered this hdd yet so no resources ,Can someone share complete pebbleb resources in pcr file format
October 29th, 2016, 1:27
Pebbleb
Seen yesterday
Loads 11 and 10
It worked
Cheers
October 29th, 2016, 1:37
Also I have discovered that full resources are available in the files.hddguru section
Thanks so much to the uploader
