Discussions related to PC-3000
Please no pirated software here!
seagate hdd tick tick after saving rom adaptives
September 30th, 2017, 13:45
hi
i changed rom adaptives in terminal
after that i saved changes to rom with command /7w1,,22
but after reseting hdd spinup and i hear tick tick sound i think rom is damaged :(
how can i fix damaged rom?
Re: seagate hdd tick tick after saving rom adaptives
October 2nd, 2017, 2:18
By writing back the original ROM.
October 2nd, 2017, 18:26
ccc wrote:By writing back the original ROM.
i have eeprom programmer can i program original rom with programmer?
October 2nd, 2017, 18:28
You're in the PC-3000 support forum, so I assume you have PC-3000. Just use that to do it.
October 2nd, 2017, 19:56
data-medics wrote:You're in the PC-3000 support forum, so I assume you have PC-3000. Just use that to do it.
thanks but rom is damaged i have no terminal even in boot code i'm sure pcb is ok because i tested rom in donor pcb but no terminal
October 4th, 2017, 3:55
Spildit wrote:Do you have PC-3000 ?
sorry spildit i dont have pc3000 i posted topic in wrong forum :oops: :oops: :oops:
