 Post subject: Best way to read a ROM from WD40NMZW-59GX6S1
PostPosted: October 29th, 2018, 11:10
do you have any good advice how to read a ROM from this drive?
Thanks.
MACROFER - data recovery
 Post subject: Re: Best way to read a ROM from WD40NMZW-59GX6S1
PostPosted: November 15th, 2018, 9:39
Hi oliver.
Check this link if you have acces to Ace blog - https://blog.acelaboratory.com/boot-rom ... rives.html
There is also a way to reprogram the ROM on newer (sata pcb) WD drives 2.5" when pcb is in busy mode. Need to solder two pins and use MX-safe adapter and follow the regular boot code procedure.
Good luck!
PostPosted: November 16th, 2018, 4:13
Banned User
i have thhis rom and model
this family need short tv9-tv10 then read rom sucess :lol:
www.njzhaobo.com
