 Post subject: recover refurbished drive OOS3000G or tp3000GB
PostPosted: February 14th, 2019, 2:52
Hi to all
newly, arrived a refurbished hdd seagete 3 tb that i think some heads are weak so i want use head map but i
can access to service area
Hdd detect
Model : OOS3000G
Serial : 00000000
Firmware : ZZZZFFFF
Capacity : 3 TB (5 860 533 168)
in log
Family ID by HDD ID: 58
Selected family......................... : 58, Grenada
Model by ID............................. : OOS3000G
Loading default settings!
Use the options dialog to review and save utility settings.
Then press OK!
Family default settings loading!
Tech Key...
En Tech err! Tech state 0xFF, 0xFF010000
Detecting SA Phys Sct Size...
Can not detect SA phys secotr size by terminal!
in terminal
Then press OK!
Tech Key...
In terminal
UNLOCK ERROR!
Spin Up
SpinOK
TCC:001B
(P) SATA Reset
ASCII Diag mode
After ctrl +L
F3 T>
Overlay PartNum: 10060942
CFW PartNum: 05272014
Overlay CompileDate: 20131006
CFW CompileDate: 20140527
OverlayCompatibilityCheck failed
Unable to load Diag Cmd Processor Overlay
some command works V1,V2,...
but other command not worked
NS DATA RECOVERY
www.nsrecovery.ir
 Post subject: Re: recover refurbished drive OOS3000G or tp3000GB
PostPosted: February 14th, 2019, 3:03
I tried load ldr but i dont know what's that fw
i have access to lba but very low speed and not stable
Thanks for any idea !
after short in terminal
Boot 0x40M
Tech Unlock Handshake: 0x98A2AE92
Reply: UNLOCK ERROR!
Spin Up
SpinOK
TCC:0020
(P) SATA Reset
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
Boot 0x40M[LBA=0x000042F9][LBA=0x000042F9][LBA=0x00066E3B][LBA=0x00066E3D][LBA=0x0000831D][LBA=0x0000831D][LBA=0x0006AE5F][LBA=0x0006AE6E]
Tech Unlock Handshake: 0xAD182DD5
Spin Up
SpinOK
TCC:0020
RECOV Servo Op=0600 Resp=0005
(P) SATA Reset
ASCII Diag mode
F3 T>
Boot 0x40M
Tech Unlock Handshake: 0x57BA644E
Spin Up
SpinOK
TCC:0020
(P) SATA Reset
Boot 0x40M
Tech Unlock Handshake: 0xE8F50467
Spin Up
SpinOK
TCC:0020
FAIL Servo Op=0055 Resp=0003
0055 071C 0456 7FFF 7FFF 7FFF 0000 0003 0000 0804 43E8 0003 FFFF 03B0 0000 3F00 0058 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
ResponseFrame 0000 0040 0000 0000 0004 FF70 0920 DFA0 0003 0F9F 0F8D 0F79 0F76 0F85 1054 105B 48DB A20F F940 FD69 8420 1886 A1AD 797F CEA6 8F45 0001 204E 2001 0001 0020 0000 0016
RECOV Servo Op=0055 Resp=0005
0055 071C 0456 7FFF 7FFF 7FFF FD00 0003 0000 0804 43E8 0003 FFFF 03B0 0000 3F00 0058 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
ResponseFrame 0000 0040 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 1054 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0002 204E 0001 0001 0020 0000 0016
SNOOOZZZZZZEEE Retry
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
MCMainPOR: Start:
User Data Base 0043F340
Check MCMT Version: Factory Init
MCInitialize: Start: Host VBM Size (Bytes): 00000210 Metadata VBM Size (Bytes):
ClearMC: Start Full Starting LBA 0000C400, Count 00432F40[0000000000001880]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
LPC Disc Xfr: EXCEPTION: ProcessRWError: Status =00000002
Next Accessed LBA = 00001880
Retry LBA = 00001880
Retry Level = 00000000
Starting LBA of RW Request=0000001880 Length=000865E8
ProcessRWError -Write- at LBA 0000001880 Sense Code=C4090081
FAIL Servo Op=0165 Resp=0003
0165 0505 0700 7FFF 7FFF 7FFF 0070 0806 3D46 0A05 43E8 4604 FFFF 0810 0000 7000 0000 000F 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
ResponseFrame 0000 0001 0000 0000 21DA E052 1F16 08A5 0000 0000 0000 0000 0000 0000 1059 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0001 204E 0000 0001 0020 0000 0019
FAIL Servo Op=008F Resp=0003
008F 0500 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
ResponseFrame 6702 0001 FFFF ED3D 21DA E052 1F16 08A5 0000 0000 0000 0000 0000 0000 1059 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0002 1000 0000 0040 0020 0000 0000
RECOV Servo Op=0165 Resp=0005
ResponseFrame 0004 0001 0004 BBDB 21DA E052 1F16 08A5 0000 0000 0000 0000 0000 0000 1170 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0004 204E 0000 0001 0020 0000 FFFF
RECOV Servo Op=0165 Resp=0005[000000002BB5420C]v00000028qv00000008qv
ResponseFrame 0000 0001 0000 0000 21DA E052 1F16 08A5 0000 0000 0000 0000 0000 0000 1053 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0009 204E 0000 0001 0020 0000 0018v00000008qv00000008qv00000008qv00000008qv00000008qv
ResponseFrame 0000 0001 FFFF ED2B 21DA E052 1F16 08A5 0000 0000 0000 0000 0000 0000 1053 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 000A 204E 0000 0001 0020 0000 FFFFv00000028qV00000008qV00000008qV00000028qV
ResponseFrame 0000 0001 FFFF ED1F 21DA E052 1F16 08A5 0000 0000 0000 0000 0000 0000 1053 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 000B 204E 0000 0001 0020 0000 FFFF
ASCII Diag mode
F3 T>V00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV
ResponseFrame 0000 0001 FFFF ED27 21DA E052 1F16 08A5 0000 0000 0000 0000 0000 0000 1053 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 000C 204E 8000 0001 0020 0000 FFFFV00000008qV00000028qV00000008qV
ResponseFrame 0000 0001 FFFF ED1D 21DA E052 1F16 08A5 0000 0000 0000 0000 0000 0000 1053 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 000D 204E 0000 0001 0020 0000 FFFF
ASCII Diag mode
ASCII Dia00000008gq Vmode
F3 T>00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV
ResponseFrame 0000 0001 FFFF ED21 21DA E052 1F16 08A5 0000 0000 0000 0000 0000 0000 1053 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 000E 204E 8000 0001 0020 0000 FFFF
ASCII Diag mode
F3 T>
RECOV Servo Op=0165 Resp=0005V00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV
ResponseFrame 0001 0001 0000 2513 21DA E052 1F16 08A5 0000 0000 0000 0000 0000 0000 1053 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 000F 204E 0000 0001 0020 0000 FFFF
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
RECOV Servo Op=0165 Resp=0005V00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000028qV
ResponseFrame 0004 0001 0004 C3B7 21DA E052 1F16 08A5 0000 0000 0000 0000 0000 0000 1053 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0010 204E 0001 0001 0020 0000 FFFF
ASCII Diag mode
ResponseFrame 0000 0001 FFFF ED07 21DA E052 1F16 08A5 0000 0000 0000 0000 0000 0000 1053 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0011 204E 0000 0001 0020 0000 FFFFV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV
ResponseFrame 0000 0001 FFFF ECFA 21DA E052 1F16 08A5 0000 0000 0000 0000 0000 0000 1053 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0012 204E 0000 0001 0020 0000 FFFFV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV
ResponseFrame 0000 0001 FFFF ECFC 21DA E052 1F16 08A5 0000 0000 0000 0000 0000 0000 1053 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0013 204E 0000 0001 0020 0000 FFFFV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV
ResponseFrame 0000 0001 FFFF ECFE 21DA E052 1F16 08A5 0000 0000 0000 0000 0000 0000 1053 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0014 204E 0001 0001 0020 0000 FFFFV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008q[000000002BB5420C]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
FAILED to spare00000903
Device Fault is set!
ClearMC: Completed, Last LBA 000043F340
MCInitialize: MC Cleared
MCInitialize: MCTBufferPtr->Header.MCTStateFlags = 0000000A
MCInitialize: MCTBufferPtr->Header.MCStateFlagsDisc = 00000001
MCInitialize: MCStateFlags = 00000001
Set MCMT Version Current
ASCII Diag mode
F3 T>
[MCMTWS] Tail/Head 0000 0000
MCInitialize: Init complete:
MCMainPOR: MCTStateFlags 00000022 MCStateFlags 00000041 Tms 000027D9
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
MSP MainPOR: Feature Disabled by AMPS
No HOST FIS-ReadyStatusFlags 0002A181
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
File comment: IDD after read rom
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: February 14th, 2019, 3:05
after search below link similar my problem
https://forum.acelaboratory.com/viewtopic.php?t=9668
also i tried read terminal but end with error
again
Thanks for any idea
File comment: try for read sa with terminal
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: February 14th, 2019, 9:25
hamidbid
Can I see it's ROM? Interesting case. Someone load an incompatible loader into it. There is a small collection. And from refarb too. Maybe something will be selected.
PostPosted: February 14th, 2019, 12:39
E123 wrote:
hamidbid
Hi E123
yes I think so
File comment: rom
ROM_00000000_37449BF1.rar [183.22 KiB]
Downloaded 1251 times
PostPosted: February 14th, 2019, 15:27
Unfortunately, I do not have a loader compatible with this ROM and there is no ROM under the overlays 2013.10.06. I can only suggest that the prototype was ST3000DM001-1CH166-899. So there is no need for an unlock. It is only necessary to make compatible ROM and overlays. In this case, I can only offer a risky solution from myself: put an available seagate updateer under 1CH166 into the disk. I have version CC29.
PostPosted: February 16th, 2019, 2:28
Thanks for answer
I never have updated fw then I don't know what happen for hard disk
maybe some sections in Rom and Service Area ? is this reversible ?
I have another Rom with another part number ? is this useful
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: February 16th, 2019, 8:14
If you have LBA access already and terminal access, then I wouldn't bother with trying to update the firmware or anything like that. You can read system file 93 by just using y-modem and the T>r93 command. Turn off all the stuff in the SAP control flags menu, then write it back using the T>w93 command and y-modem.
If for some reason that doesn't work, you can still turn off most of those functions using the F command in terminal manually. It's a bit more complex to explain how to do that, but it should work. Just shoot me a PM if you need help. I don't mind doing a remote session sometime next week.
That should resolve the speed issues.
PostPosted: February 18th, 2019, 4:05
Thanks for Answer,
F3 T>r
HighPowerMode Status 0001 Req 0002
F3 T>F
F3 T>F,,22
It 's not accept This commands in terminal , I don't think it's different with any other terminal program
hdd firmware ignore any special command
some commands are working such as V in T level or 7>x but 7>X not working
I'll be happy for your help?thanks again
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: February 18th, 2019, 4:27
I 'm very appreciate for your information
I learn very useful information about Rom
http://www.hddoracle.com/viewtopic.php? ... ab45c44c89
:D
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: February 18th, 2019, 7:38
I analyzed my refer Rom
in container segment ID 22 000100 ----030000 at both section in Rom (000000-3FFFF,40000-7FFFF)
I found
16 000040 BootFW-DIR
15 000048 General Data
0E 000248 IAP
10 000658 BootFW
03 018000 SFW
0B 02E000 Shell
00 02F100 end container
Interesting , all data in segments at two section are the same
attached all segments
22 container segment.rar [992.55 KiB]
Downloaded 1268 times
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: February 18th, 2019, 8:09
You are in the wrong direction headed. If you so want to learn ROM, then here is the F3romExplorer tool https://yadi.sk/d/SpRqMHhE3Vqkvq
And if you do not have access to the UA, then look for a way to fill compatible overlays.
I gave you an updater. And here is another, LodEdit utility:
https://yadi.sk/d/ps0J3Kns3A3KY9
You can disassemble the updater and with the F3romExplorer collect the image CC29 from your own ROM.
Then the updater will be a LOADER for your CC29.
PostPosted: February 18th, 2019, 8:20
and data in segment General Data is 27.5.2014
I think ,maybe I should find another Rom for 3 tb Grenada family and compare them with my refer to find appropriate fw
also I attached CAP,SAP,RAP my Rom
CAP-ADP-SAP.rar [20.01 KiB]
Downloaded 1295 times
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: February 18th, 2019, 8:30
Hi E123
very thanks for share files
sure , i'm going to work on and then left message
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: February 18th, 2019, 8:44
ROM CC29 + loader
https://yadi.sk/d/9FTMofTK-xE7hw
PostPosted: February 25th, 2019, 2:45
E123 wrote:
The first , I admire you for useful utility
I learn a lot :o
The second Thanks for rebuild Rom and loader
I wrote Rom with terminal after power on
got this message in terminal
Boot 0x40M
Spin Up
Trans.
Disc FW failed to load
after that I used from loader it didn't worked
again wrote refer Rom to Pcb but again got the same message
I changed PCB but again the same message!!? :?:
what happened for Hard disk?
How can I do?
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: February 25th, 2019, 3:02
I 'm a little confuse
what's date of 2013.10.06. ? How do you find this date while my data Rom is 2014.27.05?
and In last
How do I load a loader in Grenada family?
I'm so sorry for many questions?
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: February 26th, 2019, 6:35
In your screenshot, the disk has readiness in the ATA registers. Download CC29 loader by ATA. If the ABRT or ERR fails to appear in the registers, use the module "CFW_DISK" from the CC29 loader. This is your 3D loader for MRT. Use the virtual load in MRT.
For dates: do not pay attention. This is me for myself - to identify different versions of the same firmware.
PostPosted: February 26th, 2019, 9:00
Sorry, stupid.))) Of course, not an MRT, but PC3K. But the meaning is the same, only the names are different.
PostPosted: March 2nd, 2019, 4:14
Hi E123
A million Thanks for your response,
after play with loader and cfw-disk finally, I could access to sa and backup from that :D
and built head map ,disabled smp flag
IN continue I tested with another Rom( CC44) and loader (with cfwdisk) and could upgrade fw (from cc29 to cc44)
and in deeper search , I copied sysfile 20D to 20E
after power off/on
Wow :shock: :o :D
hard detect in normal mode ....
again I am really appreciate from E123 and Frank for great help in http://www.hddoracle.com/viewtopic.php?f=59&t=2173
NS DATA RECOVERY
www.nsrecovery.ir
