 Post subject: Loader for WD5000LPCX-00VHAT0
PostPosted: December 16th, 2019, 7:59
Hello I need loader for WD5000LPCX-00VHAT0
rom fw version is 0003004J. If possible can you share loader for this drive.
 Post subject: Re: Loader for WD5000LPCX-00VHAT0
PostPosted: December 16th, 2019, 10:10
I have the ROM Modules:
>ROM version............................. : 03.3PJ
>ROM F/W version......................... : 0003003P
>Overlay F/W version..................... : 03.3QJ
>Servo F/W version....................... : B1.0D
Do you want it?
ACELab partner
PostPosted: December 16th, 2019, 10:17
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 2
>Cyl Count............................... : 256
>Zone allocation table................... : Ok
>SA SPT.................................. : 1437
>ROM:
>Read ROM................................ : Ok
>ROM Data size........................... : 256 Kb
>Flash ROM dir reading................... : Ok
>Flash ROM dir reading (Ext)............. : Ok (Active)
>Modules directory address............... : 174 131
>SA regions address...................... : by default
>SA regions address (RAM)................ : by default
>Module 02 access........................ : Granted
>SA Translator loading................... : Ok
>ROM Modules:
>ROM version............................. : 03.4JN
>ROM F/W version......................... : 0003004J
>Overlay F/W version..................... : 03.4KN
>Servo F/W version....................... : G5.0D
>Heads configuration..................... : by map
>Heads number in use..................... : 2
>Switched off heads...................... : No
>Heads map............................... : 0,1
>Service area:
>SA dir reading (ID)..................... : Ok
>SA Access............................... : Copy 0,Copy 1
11.rar [502.23 KiB]
Downloaded 608 times
PostPosted: December 16th, 2019, 10:19
Coincidently, I also have a rare "HubLT2" in and need LDR for it..
WD5000LUCT-63RC2Y0
>Techno mode key
>RAM:
>ROM:
>Modules directory address............... : 70 545
>ROM Modules:
>ROM version............................. : 03.3RK
>ROM F/W version......................... : 0003003R
>Overlay F/W version..................... : 03.3RK
Thanks!! :-)
PostPosted: December 16th, 2019, 11:53
It's OK, I got it from the drive in the end!! :-)
Will upload to files section....
PostPosted: December 16th, 2019, 12:12
http://files.hddguru.com/index.php?acti ... ty/HUBLT2&
