 Post subject: Unable to create head map
PostPosted: July 26th, 2020, 3:27
Hi everyone im working on Samsung 1tb u can serial no. And Model no. I have cut head2 as it was having scratches and head1 not ok and slist module is damage in head0 I changed head map in RAM drive detecting I COPIED FIRMWARE FROM HEAD0 but not able to create head map in DE can you suggest me what to do ?
Can I replace Slist module with do ornate drive module ?
 Post subject: Re: Unable to create head map
PostPosted: September 1st, 2020, 16:46
No you cant. Slist is very significant to be original.
Angel Data Recovery
PostPosted: September 2nd, 2020, 9:46
is it damaged in the used area? If not, you can still use it for head map building, however, you need to convince the drive to load it somehow.
Users browsing this forum: No registered users and 14 guests
