 Post subject: MQ01UBD100
PostPosted: October 20th, 2021, 9:20
Hi to all!
Is Data Recovery...
is backup all modules only CP DD is bad!
Is CP DD is bad!
how to fix? (without losing the data)
PC EXPRESS
Нет ничего невозможного
 Post subject: Re: MQ01UBD100
PostPosted: October 20th, 2021, 10:08
Are you not reading anything in DE ? Try reading using the utility. I don't think the MQ01 are SMR but I'm sure someone will correct me if it is and if that is the case you're really going to need the p-list.
PostPosted: October 20th, 2021, 10:15
Thanks reply!
It sees data but is very slow and stops reading all the time.
PostPosted: October 20th, 2021, 10:34
What's the g-list like? Sometimes slow data is better than no data. If it's tripping into errors reading but picks up after a reset try reading without udma. Slower again but may be more stable.
PostPosted: October 20th, 2021, 10:49
MQ01 is not SMR.
you can probably read by util without plist, albeit with shifts. Wondering if it reads anything useful when it reads slowly...
PostPosted: October 20th, 2021, 14:11
@sempre, can you read the tracks in this model? Can you do a partial read of CP DDh?
If you can at least read the important sectors in this CP, I believe I could write a dd script to remove the shifts in the clone.
PostPosted: October 21st, 2021, 7:19
Thanks All helps!
Solved!
Closed!
Users browsing this forum: No registered users and 52 guests
