 Post subject: WD20EZRZ-22Z5HB0 LDR file needed
PostPosted: November 28th, 2021, 22:49
hello can somebody provide the LDR file and modules for this hdd?
MDL : WD20EZRZ-22Z5HB0
DMC : HHNNKT2CAB
i can give a small donation for your help^^
 Post subject: Re: WD20EZRZ-22Z5HB0 LDR file needed
PostPosted: November 29th, 2021, 4:33
what version?
PostPosted: November 29th, 2021, 21:06
Sir you means the version of firmware?
PostPosted: November 30th, 2021, 5:24
Yes, you need to specify fw version.
PostPosted: November 30th, 2021, 21:10
Northwind thank you for your answer. i really apreciate it.
this is my firmware info
>ROM Modules:
>ROM version............................. : 15.0BC
>ROM F/W version......................... : 0015000B
>Overlay F/W version..................... : 15.0BC
>Servo F/W version....................... : 02.67
PostPosted: December 1st, 2021, 4:06
There are 001500B in the Diablo 3S section here http://files.hddguru.com/download/PC-30 ... ablo%203S/
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: December 1st, 2021, 4:53
digisupport thank you for your answer. i got the rom from HDDGURU but unfortunatelly no LDR file :( :( :( :(
PostPosted: December 1st, 2021, 5:03
Here you go:
15000B Diablo 3S WD20EZRZ-00Z5HB0.zip [19.96 MiB]
Downloaded 381 times
PostPosted: December 1st, 2021, 8:24
Use the one from Northwind ^^^^ or the one I uploaded this morning :)
PostPosted: December 2nd, 2021, 2:26
Guys thank you for the help.
still no success! i guess donor heads not copatible or cannot read the SA because of platters scratches.
i just started a year ago and i feel very shy to ask for advices .. i still have many things to learn...
PostPosted: December 2nd, 2021, 4:32
From your picture, it looks like the drive has been opened.
Did you open it?
Did you maintain clean room conditions?
What did you see inside?
What was the drive behavior before you opened it?
Do tell. Don't be shy.
PostPosted: December 2nd, 2021, 4:51
The more questions you ask, the quicker you will learn :) Don't worry about asking, besides who cares what we think about you? :wink:
Adding to northwind's questions.
What's the history on the drive.
What was it doing originally.
Can you post a picture of the donor label.
PostPosted: December 2nd, 2021, 21:28
Guys your answer are really really kind. as you know many people doesnt want to share their experience .so i feel lucky when you give me an answer thank you very much for your patience :D .
according to customer the HDD tarted to make weird sound. i thought bad heads so i prefer to do not power on in order to avoid more damage,
and ta daaaaan platter sratches.
the rotation of the motor made the top ring scratch with the cover surface of the HDD.. part of the surface turned like a orange peel.
and then while rotating went on the heads and then scratches.....
sorry for my bad english. im not native speaker
the donor heads seems compatible. iw as confident.... but after i tested on the patient. heads stop to work .
maybe broken due of the scratches on the platters....... i guess
PostPosted: December 2nd, 2021, 21:44
this is the DONOR drive
PostPosted: December 2nd, 2021, 22:19
here the photo of the ring peel and scratches :( :( :( :( :( :(
PostPosted: December 3rd, 2021, 4:37
I'd call those are scores rather than scratches. If you have a green light and tilt the drive I think you'll find the top surface will look like someone has been ice skating on it.
Assuming there's no physical damage to the top cover.
The centre ring damage was probably caused by the head arm contacting it.
Heads won't be able to track past the scores or defect.
The defect looks like a head was stuck and then ripped off.
As I understand your response, you have tried putting the heads back in the donor and they now don't work, they have probably been damaged on the patient. Did the original HSA have any physical damage or heads missing?
Options now are limited, you will need to check the other platter surfaces for damage and contamination before anything else. Unless the client is very serious and accepts the risks/probabilities about their recovery I hate to say it but it may be best to stop at this point.
PostPosted: December 3rd, 2021, 4:46
Yeah, it doesn't look good at all.
I think this drive needs to be disassembled to have other surfaces inspected; based on that, it will be either unrecoverable or if other surfaces look good, then a partial recovery might be possible. I wouldn't hold my breath, though.
By the way, I've never seen the washer getting peeled off like this.
