Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
 Post subject: Re: Seagate Mobile HDD ST1000LM035 Rom Reading failure
PostPosted: June 21st, 2022, 16:55
yes, if you don't get any output over serport, then there is likely some hw damage. Fix that first or move rom chip to a working pcb.
PostPosted: June 26th, 2022, 1:44
Yes there could be internal track or other electronic issue. Unfortunately manual chip reading is not possible so I have finally given up.
Thanks a lot.
PostPosted: June 26th, 2022, 7:43
how about moving the rom chip to a known good pcb?
PostPosted: June 27th, 2022, 10:02
Hi pepe
Unfortunately I can't remove ROM from 2.5" disk PCB (can only desolder TSOP type desktop roms) .
Actually I don't know which type of ROM chip this model has .
PostPosted: June 27th, 2022, 12:49
terminator2 wrote:
Hi pepe
ROM chip is typical serial flash but in a WLCSP-8 P8 package. Tiny but possible to move or read via external programmer.
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: June 28th, 2022, 2:58
digisupport wrote:
terminator2 wrote:
Hi pepe
Thanks a lot :good: :-D
I will give it a try
PostPosted: October 5th, 2022, 2:41
whats the final solution for it?
i m having same case
PostPosted: November 2nd, 2022, 11:35
I have a similar issue here with a Seagate with Model No. ST1000LM035 FW: RKM2
When I Power on Drive I get the following error
Boot0x80M
LED:0x000000BB FAddr:0x00005807
When I tried ROM via Terminal I get the following error..
Boot Code: Can not get the current address!
I was able to Read ROM Via Programmer and Write to Donor PCB, still didn't work, and did not Power any other PCB.
I tried to import RAP, CAP SAP and IAP from Donor ROM.. it gives following error,
Boot Code: Can not get current address!
I called ACELAB TS for help, I was told "BootFW segment is damaged.
We can not fix this problem"
I have attached the Original ROM read from Programmer.
If anyone can help check it out..
Thank you
WKPNVX4B_ROM.rar [254.67 KiB]
Downloaded 187 times
Oladoja Bankole
Exclusive Data Recovery Lab
Nigeria, Abuja
http://www.edarlab.com
Users browsing this forum: Google [Bot] and 47 guests
