 Post subject: Help]How do I load the translator to ram for spyglass drive?
PostPosted: January 23rd, 2023, 17:55
Hi all
Long time since I had to do this procedure so I lost the right steps. Please help me :)
I got WD40NMZW-11GX6S1-01.01A01 drive with bad pcb. After converting the USB to SATA and blocked module 02 access I got full SA access but no user data access.
How do I load or initilize the drive by loading the translator to RAM to get full drive ID?
I attending to this approche because the solution for slow responding drive may damage the original translator so I want to load the translator to ram and use the solve responding solution for the ram only.
I hope I succeed to explain myself.
Best Regards,
 Post subject: Re: Help]How do I load the translator to ram for spyglass dr
PostPosted: January 23rd, 2023, 19:02
write it to ram.... but i doubt that would work after starting it with 02 blocked...
PostPosted: January 23rd, 2023, 19:48
I solved the case,
Thank you pepe for your respond :)
PostPosted: January 23rd, 2023, 20:32
Did the original PCB have a dry solder joint at the zero-ohm resistor near the USB connector?
PostPosted: January 28th, 2023, 13:36
I didn't check
I solved the case by converting the board to sata and did some modifications on the SA.
