 Post subject: FW Request:WD2500AAJS-22VWA0
PostPosted: July 27th, 2023, 21:50
Does anybody have firmware for WD2500AAJS-22VWA0 please
Zero Alpha: zeroalpha.com.au
Find Cheap Donor Drives App: https://www.zeroalpha.com.au/donor-drive-app Updated February 2026
 Post subject: Re: FW Request:WD2500AAJS-22VWA0
PostPosted: July 29th, 2023, 4:14
What version do you need ?
There are 6 firmwares in the files section here..
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: July 29th, 2023, 19:46
I need 005800A3 not in files section
PostPosted: July 30th, 2023, 10:43
https://firmware.hddsurgery.com/index.p ... rnado%202D
PostPosted: July 30th, 2023, 19:17
unknown wrote:
https://firmware.hddsurgery.com/index.php?manufacturer=Western%20Digital&family=Tornado%202D
:) I already tried mr hddsurgery but they only have 005800A3 in WD3200. Which kind of worked. I really need to try WD2500AAJS-22VWA0: 005800A3
PostPosted: August 29th, 2023, 0:51
I finally got the firmware for this and solved the case! The head map probably stopped other versions from working.
I'll leave this here for anybody with a similar case. PM for firmware.
Family:................................. : Tornado 2D
Techno mode key......................... : Ok
HDD Status sector....................... : Ok
RAM:
System controller (SoC)................. : 88i6745B1 0x(42B1)
HDD Info reading........................ : Ok
Heads number............................ : 3
Cyl Count............................... : 128
ROM:
Read ROM................................ : Ok
ROM Data size........................... : 192 Kb
Flash ROM dir reading................... : Ok
SA regions address...................... : by default
SA regions address (RAM)................ : by default
Module 02 access........................ : Granted
SA SPT.................................. : 857
SA Translator loading................... : Ok
SA defects assigned..................... : 1
Reading by ABA may get wrong data
ROM Modules:
ROM version............................. : 58.A3D
Module 4F F/W version................... : 005800A3
Overlay F/W version..................... : 58.A3D
Servo F/W version....................... : 01.0L
Heads configuration..................... : by map
Heads number............................ : 4
Heads number in use..................... : 3
Switched off heads...................... : Yes
Heads map............................... : 1,2,3
Relocations............................. : 0 (1 465)
Read ROM DCM............................ : Ok
Power up log reading.................... : Ok
Power up load dir data.................. : Yes
Power up load permovl................... : Yes
Power up load CFG data.................. : Yes
