Post new topic Reply to topic  [ 40 posts ]  Go to page 1, 2  Next
 Post subject: Seagate 9B V11 family firmware diagnostics
PostPosted: May 21st, 2024, 10:40
Hi friends
I have got this 4 TB disk , it is giving sector access errors .I have taken resources backup and backed up system files (sysfile 28 can't get copied from terminal)
I am getting errors while disabling background process.
What will be safest steps to follow.
 Post subject: Re: Seagate 9B V11 family firmware diagnostics
PostPosted: May 21st, 2024, 22:56
Hi
I am getting fw not supported error what it means & how can I correct it.
Anyone pls. help. Thanks
PostPosted: May 22nd, 2024, 7:24
fw does not support writing sysfile thru terminal.
you need to write over ata.
PostPosted: May 22nd, 2024, 11:40
Thank you pepe
I will give it a try , disk loses ready ness often and I will have to enter utility again , initially it was giving ID but after patching rom it has lost normal detection ,after unlocking , re reading id is required.
I have been advised not to do experimentation with this SED drive as any single mistake may make recovery impossible for a pro also.
I am bit worried though I have backed up everything data is crucial and I don't want to take any risk
PostPosted: May 22nd, 2024, 21:11
I am unable to write sys file 93 by both ATA methods as disk loses readyness , is there anything I am still missing.
PostPosted: May 23rd, 2024, 4:19
what's goning on on the terminal?
PostPosted: May 23rd, 2024, 10:42
Hi Thanks
Here is terminal output
Skip Error Type Decision due to Small Sector count 0x0001
Out: [PRA]!
Starting LBA of RW Request=00213CCE9F Length=00000B34
ProcessRWError -Read- at LBA 00213CD6A4 Sense Code=43110081
Out: [PRA]!
ProcessRWError -Read- at LBA 00213CD6A8 Sense Code=43110081
Out: [PRA]!
ProcessRWError -Read- at LBA 00213CD6AE Sense Code=43110081
Out: [PRA]!
RAW ON After Spinup for counter=0x00000020, BlkAddr=0x003A6A960A
LBA = 00000000213CD2D7[ScrubRemove]!
LBA = 00000000213CD617[ScrubRemove]!
LBA = 00000000213CD619[ScrubRemove]!
CNcp
AStDisc
ProcessRWError -Read- at LBA 00213CD6C3 Sense Code=43110081
Out:
CNcp
AStDisc
CNcp
AStDisc
RAW Reallocate [RA]!
Common path start quit now
ProcessRC: 00000001,00000000
SkipLen: 00000000
ReadContinuous: 213CD617,000003BC
UnrecovSectorCount:0306,03B0
NumUDEs: 00000306,00000000,000003B0
Passed: 00000080,0000017E,0000035C
Out:
[SpawnDiscNodes: 213CD61E,000003AA-09E674F8,000059A0] ==> BRO is in progress
SkipLBA: 213CD61E,213CD9C7
Starting LBA of RW Request=000346FC42 Length=00001B60
ProcessRWError -Read- at LBA 000347027E Sense Code=43110081
Out:
ReallocateLBA1: 0347027E Length: 00000001
RST Status
NumMediaCacheEntries: 00000400
NumTotalEntries: 000005CA
SCT Status
MC1stSparePBA: 3BD5CAA0 MCLastSparePBA: 3BD7455F
User1stSparePBA: 3B242A41 UserLastSparePBA: 3B312B4D
FAILED to spare00000101!
CNcp
CNcp
CNcp
CNcp
CNcp
CNcp
NVCScram Saved HB Size:020A
LD: MD_Alloc:00000098 HB_Alloc:0000 MD_Alloc:80380000 HB_Alloc:8032 FlashRestore
PowerDevReg 7E: 7001 PowerDevReg 7D: 0044 MD_Saved:00000098 HB_Saved:00000000 MD_CRC:DBF9
PP: MD_Alloc:00016800 HB_Alloc:0000 FlashRestore
PVTSize: 00046888 CompSize: 000025AA DeCompSize: 00046888 MD_Saved:000025AA HB_Saved:00000000 MD_CRC:D057
MC: MD_Alloc:00003000 HB_Alloc:0000 FlashRestore
DataLength: 00000310 MD_Saved:00000310 HB_Saved:00000000 MD_CRC:4C0E DataLength: 000025AA
DSP0436
2Sync:0 4
NECS: CorruptedSectorsRecon - Head:00003FE9 Tail:00003D66
LastWrittenDiscLBA : FFFFFFFFFFFFFFFF
MCMainPOR: MediaCacheDiscStateFlags 0000002A MCStateFlags 00405141
6Gb Max Speed lowered to 3Gb for Intel bug
Send Status: COMRESET seen
FIS34
ENP0436
2Sync:1 C
Di 27
F3 T>
PostPosted: May 24th, 2024, 6:03
Show NGList.
PostPosted: May 24th, 2024, 9:57
Disk Solution wrote:
Show NGList.
Hi Disk Solution here is NRG list
PostPosted: May 26th, 2024, 1:46
Disk loosing readyness might indicate weak heads.
PostPosted: May 26th, 2024, 7:16
Thanks . I am unable to write sysfile 93 bt ATA indirect so background scanning is not disabled. I think issue could in in SA or weak head 0.
While writing terminal gives LED error
LED:0x000000BD FAddr:0x00009039
Disks health is 9% it has lots of smart errors , should I clear smart
PostPosted: May 26th, 2024, 7:36
How to interpret this terminal
CNcp
AStDisc
CNcp
AStDiscRAW OFF for RAW Head=03 counter=0, End BlkAddr=0x003B242C84
CNcp
AStDisc
CNcp
AStDisc
ProcessRWError -Read- at LBA 00213CCEA3 Sense Code=43110081Out:
Starting RAW ReWrite
CNcp
AStDisc
CNcp
AStDisc
CNcp
AStDisc
CNcp
AStDisc
CNcp
AStDisc
CNcp
AStDisc
CNcp
AStDisc
CNcp
AStDisc
CNcp
AStDisc
CNcp
AStDisc
CNcp
AStDisc
CNcp
AStDisc
CNcp
AStDisc
CNcp
AStDisc
CNcp
AStDisc
CNcp
AStDisc
CNcp
AStDisc
PostPosted: May 27th, 2024, 0:29
CNcp
AStDisc
CNcp
CNcp
AStDisc
CNcp
AStDisc
CNcp
AStDisc
CNcp
AStDisc
CNcp
AStDisc
CNcp
AStDisc
CNcp
AStDisc
CNcp
AStDisc
CNcp
AStDisc
CNcp
AStDisc
CNcp
AStDisc
CNcp
AStDisc
CNcp
AStDisc
CNcp
AStDisc
CNcp
AStDisc
CNcp
AStDisc
CNcp
AStDisc
CNcp
AStDisc
CNcp
AStDisc
Sense Code =XXXX 82 - Problem with sector translation (broken translator )
sense Code = XXXX 81 Bad Sector not translator .
Try to patch sysfile 93 that might solve this case.
PostPosted: May 27th, 2024, 2:03
let me disagree, there are several error codes ending with 81 and 82, each having different meaning.
PostPosted: May 27th, 2024, 2:35
Thanks pepe
PostPosted: May 27th, 2024, 2:36
Can someone pls. take remote control to update sysfile 93 as I have given up now & about to return it as unrecoverable.
PostPosted: May 27th, 2024, 4:45
I can look it online PM me. Looks like defects lists, 1 NGlist defect enough to multifunction full drive.
PostPosted: May 27th, 2024, 17:18
yes, but this one looks original...
PostPosted: May 27th, 2024, 19:20
Try issuing the following terminal commands at level T (WARNING: commands are Case SenSiTive).
F"READ_SPARING_ENABLED",0,22
F"WRITE_SPARING_ENABLED",0,22
F"OFFLINE_SPARING_ENABLED",0,22
F"DAR_ENABLED",0,22
F"DISABLE_IDLE_ACTIVITY",1,22
F"BGMS_DISABLE_DATA_REFRESH",1,22
F"ABORT_PREFETCH",1,22
F"READ_LOOKAHEAD_DISABLED_ON_POWER_UP",1,22
F"READ_CACHING_DISABLED_ON_POWER_UP",1,22
PostPosted: May 28th, 2024, 4:34
F"DAR_ENABLED",0,22
Thank you fzabkar
here is response for each command --
F3 T>F"READ_SPARING_ENABLED",0,22
Drive AMPS Configuration has been modified from compiled defaults.
Drive must be re-initialized to controller firmware defaults by re-downloading controller firmware
DO NOT SHIP WITHOUT FIRST RE-DOWNLOADING CONTROLLER FIRMWARE OR RESETTING TO DEFAULTS!
(D) SATA Reset
Byte:0092: Bit:6, READ_SPARING_ENABLED = 0
F3 T>F"WRITE_SPARING_ENABLED",0,22
(D) SATA Reset
Byte:0092: Bit:7, WRITE_SPARING_ENABLED = 0
F3 T>F"OFFLINE_SPARING_ENABLED",0,22
(D) SATA Reset
Byte:0455: Bit:1, OFFLINE_SPARING_ENABLED = 0
F3 T>F"DAR_ENABLED",0,22
(D) SATA Reset
Byte:0455: Bit:0, DAR_ENABLED = 0
F3 T>F"DISABLE_IDLE_ACTIVITY",1,22
(D) SATA Reset
Byte:0455: Bit:6, DISABLE_IDLE_ACTIVITY = 1
F3 T>F"BGMS_DISABLE_DATA_REFRESH",1,22
(D) SATA Reset
Byte:010C: Bit:1, BGMS_DISABLE_DATA_REFRESH = 0
F3 T>F"ABORT_PREFETCH",1,22
(D) SATA Reset
Byte:00DA: Bit:6, ABORT_PREFETCH = 1
F3 T>F"READ_LOOKAHEAD_DISABLED_ON_POWER_UP",1,22
(D) SATA Reset
Byte:00E4: Bit:5, READ_LOOKAHEAD_DISABLED_ON_POWER_UP = 1
F3 T>F"READ_CACHING_DISABLED_ON_POWER_UP",1,22
(D) SATA Reset
Byte:00DA: Bit:0, READ_CACHING_DISABLED_ON_POWER_UP = 1
F3 T>
