 Post subject: How to Deselect particular file types & subfolders from DE
PostPosted: June 1st, 2024, 2:42
I want to recover large data having many folders /subfolders & files.In order to minimize time I want to deselect particular file extensions from entire task.
How can I skip all particular file extensions as doing it manually is very much time consuming.
While I can select particular file extension or folder names from find files /folders in DE so that all those specific files I can copy ,but I want to do opposite want to remove particular file extensions from large no of files.
Any suggestion or tip.
 Post subject: Re: How to Deselect particular file types & subfolders from
PostPosted: June 1st, 2024, 3:09
can't you simply select all, then use find files as you wrote and deselect the result?
PostPosted: June 1st, 2024, 3:37
Thanks pepe
Yes that's good solution ,I will have to select each required file type & recover & repeat this exercise .Is it possible to select multiple file types at a time (*.xls ,*.jpg ,*.pdf ,*.doc,*.xlsx etc ) then that will solve my purpose.
PostPosted: June 1st, 2024, 6:41
i think finding multiple templates is allowed, separated with semicolon, then you select files in result.
PostPosted: June 1st, 2024, 8:02
OK great that will save lots of my time. I have to select single head out of 4 & do imaging of all required files & skip others 4 times .I have tried earlier but instead of semicolon I put comma . I thought its not supported.
Thanks a lot pepe :D
Users browsing this forum: No registered users and 58 guests
