 Post subject: Sata conversion PCB 2060-810082
PostPosted: April 8th, 2024, 16:27
I have this PCB in the image below, and I need to convert it to SATA because I suspect there is a problem with the head. However, I did not find compatible PCB records.
Has anyone ever needed to convert this PCB model?
I could try to solder a SATA connector to the terminals and convert, but I would prefer a less invasive solution
HDD Model: WD20JDRW-11C7VS0
DATE: 15 AUG 2023
PCB: 2060-810082-000 P0
 Post subject: Re: Sata conversion PCB 2060-810082
PostPosted: April 8th, 2024, 17:37
You need something like this: https://www.hddheadtools.com/wd-smr-hdd ... rd-drives/
ACELab partner
PostPosted: September 19th, 2024, 21:53
Can you guys pinpoint me what components to remove. I see 4 resistors. Where is the oscillator?
PostPosted: September 19th, 2024, 21:59
Found it. Nevermind
Remove this components and solder sata like in the post
PostPosted: September 19th, 2024, 22:33
Leave the crystal alone if you are going to remove the capacitors (not "resistors"). Clearly you have no idea what you are doing or why you are doing it, so perhaps it would be best to outsource this job.
Otherwise ...
Locating the Reset* pin on USB-SATA bridge ICs:
https://www.hddoracle.com/viewtopic.php?f=59&t=3381
Users browsing this forum: No registered users and 78 guests
