 Post subject: ST2000DM005 read sector only with utility mode please HELP
PostPosted: December 19th, 2024, 21:09
Hi im strugling with this drive 1 week already!
it the begining the drive was BSY. iv patched and backup sys file 1b,35,93 but 28 file i could read only copy 1! so i changed sys file 93 settings and i could clone about 40% of the drive!
then the drive started to get busy! iv changed to utility mode and i can read the sectors! "SUPER SLOW"
so i cleared G-LIST and SMART and regenerated the translator but same situation
now i get alot of sys file error ............ maybe P-list problem?
please kindle give me some advices
Boot 0x0100MAF1130001
SpinUp
TCC:0021
[LBA=0x00000898]N02020C20o0o0o0o0o0o0o0o000[LBA=0x00000898]NO1111102020C20o0o0o0o0o0o0o0o0001111102020C20o0o0o0o0o0o0o0o0001111102020C20o0o0o0o0o0o0o0o00011Bailing SOVABusy bit check to avoid hang11102020C20o0o0o0o0o0o0o0o0001111102020C20o0o0o0o0o0o0o0o0001111102020C20o0o0o0o0o0o0o0o0001Bailing SOVABusy bit check to avoid hang111102
SIM FileFD=FC000000 ErrorCode=43160080 DiscLBA=0000000000000898 Duration=000005C4 ms[LBA=0x000010D1]N02020C20o0o0o0o0o0o0o0o000[LBA=0x000010D1]NO1111102020C20o0o0o0o0o0o0o0o0001Bailing SOVABusy bit check to avoid hang1Bailing SOVABusy bit check to avoid hang11102020C20o0o0o0o0o0o0o0o0001Bailing SOVABusy bit check to avoid hang1Bailing SOVABusy bit check to avoid hang11102020C20o0o0o0o0o0o0o0o0001Bailing SOVABusy bit check to avoid hang1Bailing SOVABusy bit check to avoid hang11102020C20o0o0o0o0o0o0o0o0001Ba
SIM FileFD=FC00420D ErrorCode=43160080 DiscLBA=00000000000010D1 Duration=00000823 ms
Trans
Tech Unlock Handshake: 0xA1DE6444
Reply:
Rst 0x0100MAF11300001
SIM_ReadyDiskFile failure1 :
ErrorCode : 0x00001002
SIM_ReadyDiskFile read again
SIM_ReadyDiskFile failure2 :
SIM_BrokenList is full
(P) SATA Reset
SIM FileFD=FC3BB200 ErrorCode=43160080 DiscLBA=0000000000017849 Duration=000006D7 ms
NVCScram Saved HB Size:020A
LD: MD_Alloc:00000098 HB_Alloc:0000 MD_Alloc:80380000 HB_Alloc:8032 FlashRestorePowerDevReg 7E: 7001 PowerDevReg 7D: 0044 MD_Saved:00000098 HB_Saved:00000000 MD_CRC:DC13
PP: MD_Alloc:00016800 HB_Alloc:0000 FlashRestore
PVTSize: 00025664 CompSize: 000004C8 DeCompSize: 00025664 MD_Saved:000004C8 HB_Saved:00000000 MD_CRC:9E85
MC: MD_Alloc:00003000 HB_Alloc:0000 FlashRestore
DataLength: 00000310 MD_Saved:00000310 HB_Saved:00000000 MD_CRC:4C0E DataLength: 000004C8
DSP0003
2Sync:0 4
[Recover : 0xFC000000 ==> PASS]
[Recover : 0xFC001064 ==> PASS]
[Recover : 0xFC3A81D2 ==> PASS]
[Recover : 0xFC368019 ==> PASS]
[Recover : 0xFC36901A ==> PASS]
[Recover : 0xFC36E01E ==> PASS]
[Recover : 0xFC38C132 ==> PASS]
[Recover : 0xFC3BA071 ==> PASS]
[Recover : 0xFC389115 ==> PASS]
NECS: CorruptedSectorsRecon - Head:00000000 Tail:00000000
LastWrittenDiscLBA : FFFFFFFFFFFFFFFF
MCMainPOR: MediaCacheDiscStateFlags 0000002A MCStateFlags 00020041
6Gb Max Speed lowered to 3Gb for Intel bug
Send Status: COMRESET seen
FIS34
ENP0003
2Sync:1 C
SIM FileFD=FC35614E ErrorCode=43160080 DiscLBA=000000000001D690 Duration=00000762 ms
SIM FileFD=FC35614E ErrorCode=43160080 DiscLBA=000000000001D690 Duration=0000078F msIDLE1Bailing SOVABusy bit check to avoid hangBailing SOVABusy bit check to avoid hangBailing SOVABusy bit check to avoid hang
SIM FileFD=FC35614E ErrorCode=43160080 DiscLBA=000000000001D690 Duration=000007BB ms
SIM FileFD=FC35117D ErrorCode=43160080 DiscLBA=00000000000180E4 Duration=000005FA msBailing SOVABusy bit check to avoid hangBailing SOVABusy bit check to avoid hangBailing SOVABusy bit check to avoid hangBailing SOVABusy bit check to avoid hang
SIM FileFD=FC35614E ErrorCode=43160080 DiscLBA=000000000001D690 Duration=00000834 ms
Di 21Bailing SOVABusy bit check to avoid hangBailing SOVABusy bit check to avoid hangBailing SOVABusy bit check to avoid hangBailing SOVABusy bit check to avoid hangBailing SOVABusy bit check to avoid hangBailing SOVABusy bit check to avoid hang
SIM FileFD=FC34D135 ErrorCode=43160080 DiscLBA=000000000001D667 Duration=00000834 msBailing SOVABusy bit check to avoid hangBailing SOVABusy bit check to avoid hang
SIM FileFD=FC34D135 ErrorCode=43160080 DiscLBA=000000000001D667 Duration=00000856 ms
Di 21
Di 21
TCC:0021 EMCDataErr:0000000C
 Post subject: Re: ST2000DM005 read sector only with utility mode please HE
PostPosted: December 20th, 2024, 0:14
Whats wrong with copy 0? Who told you to clear and regen translator? Be careful doing this on ST2000DM005
Zero Alpha: zeroalpha.com.au
Find Cheap Donor Drives App: https://www.zeroalpha.com.au/donor-drive-app Updated February 2026
PostPosted: December 20th, 2024, 1:29
Sir i coulnd read copy 0! the HDD freezes any time i try
PostPosted: December 20th, 2024, 2:43
Sounds like Pebcak issue.
PostPosted: December 20th, 2024, 2:54
what is a pepcak Sir?
