Discussions related to PC-3000
Please no pirated software here!
February 5th, 2025, 8:54
Hi I have a Kingstone SATA SSD with CP33238B
but after shorting the pin to start Safe mode I get this error
I am using Acelab PC PATA-SATA
- Attachments
- SATA-PATA.PNG (10.43 KiB) Viewed 17095 times
February 5th, 2025, 9:48
And when starting the program you select the appropriate PATA port, not SATA?
February 5th, 2025, 12:30
Lukas wrote:And when starting the program you select the appropriate PATA port, not SATA?
Yes
February 6th, 2025, 3:00
The message clearly suggests using the application's SATA port rather than the PATA port.
If everything is connected correctly on original Acelab adapters contact their support.
February 6th, 2025, 3:21
No, the message says the utility has problems getting data through the INTERNAL (on-board, marvel 88SA8052) PATA-SATA bridge and suggests to use one of the PATA ports with the jmicron PATA-SATA (JMS20330) bridge attached. You also need to start the util using the PATA port.
February 6th, 2025, 4:02
pepe wrote:You also need to start the util using the PATA port.
That's exactly what I mean.
February 9th, 2025, 10:37
I am using the original PATA-SATA that came from Acelab
