Discussions related to PC-3000
Please no pirated software here!
I'm curious about smr such as Seagate Rosewood Mobile.
February 6th, 2025, 6:12
If the translator problem is unc, I wonder if I should do the translator recovery first or erase the smart erasure and non g-list and regenerate the translator.
mcmt error: I can't read 340.
Smr is known to have about 100GB of data hidden in MCMT.
So I don't recommend playing the translator, is it correct to restore the translator??
Important modules backed up.
Except for 340 mcmt.
It can't even be read from the outside.
Re: I'm curious about smr such as Seagate Rosewood Mobile.
February 6th, 2025, 20:11
These problems should be left alone for experienced engineers only.
March 14th, 2025, 17:42
Well, MCMT is 348 for starters.
March 16th, 2025, 22:03
Zero Alpha wrote:These problems should be left alone for experienced engineers only.
Thank you for your answer!
for personal disposal
I'm practicing with a broken hard drive, so I'm studying hard by myself!
March 16th, 2025, 22:04
beefstrudel wrote:Well, MCMT is 348 for starters.
Thank you for your response.
If it's broken, is it correct to read by force after recovery to sa lba and then read by ram using the option?
I'm asking because I'm not sure.
March 17th, 2025, 3:06
If possible avoid writing anything to SA. Use write protection.
Read the necessary system files, how they are best read depends on the drive.
A lot of manual correction can be necessary, load into RAM and access data.
Part of the process is well documented in the manual and ACE blog.
March 17th, 2025, 21:08
digisupport wrote:If possible avoid writing anything to SA. Use write protection.
I read the article to activate the protection option, read the system file and applied it to low quality REM.
But is there a way to check the checksum when there is an error in the system file??
I'm curious about the checksum method.
Is there a way to check if the file system is corrupted after a forced read?
I'm asking to study!
March 19th, 2025, 22:52
I want to study about this function.
But how should I study this function?
If the original is broken, I wonder how I can check the checksum and how I can do it if both the fixed one and the original one are broken.
March 20th, 2025, 0:55
use good ones first to analyze the structure and find out CS protected blocks, etc
March 20th, 2025, 2:35
pepe wrote:use good ones first to analyze the structure and find out CS protected blocks, etc
Is it correct to buy a good one first and study firmware in it?
Thank you!
