Discussions related to PC-3000
Please no pirated software here!
Re: ST4000NM0035
August 26th, 2021, 17:19
Hm, i thought he used a TN03 rom and copied adapts in there.
It will probably work this way...
Re: ST4000NM0035
August 27th, 2021, 2:08
pepe wrote:i doubt it would do any good, as the CFW is not compatible with the OVLs in the SA.
Did you check it?
AIUI, this firmware keeps a backup copy in a container. The ROM has two "csiD" containers -- one has the original TN03 firmware components while the other has TN05. @E123 has merely reverted to the original container.
It works, i test it...
can i find the way to made the rest of pcs. same as this one?
Thank you @E123 for helping and you guys for your time to reply to me.
Re: ST4000NM0035
August 27th, 2021, 2:59
Popica wrote:can i find the way to made the rest of pcs. same as this one?
I know what to do, but perhaps you should compensate @E123 for his time. I believe he normally charges a very small sum for Seagate firmware modifications.
Re: ST4000NM0035
August 27th, 2021, 3:53
i will try to do all what i can , hope to can i do it all
Re: ST4000NM0035
August 31st, 2021, 6:28
UPDATE
Thank you @E123 and @fzabkar for your time, i succed also to handle the fully and permanent unlocking on those and reverted to TN05 fw completly unlocked.
Re: ST4000NM0035
October 15th, 2021, 8:53
have now same issue at ST8000NM0045, and that solution dont work like in 4TB seagate...maybe need another step in plus
Re: ST4000NM0035
October 15th, 2021, 13:27
Repairing ROM from bad Seagate firmware update:
http://www.hddoracle.com/viewtopic.php?f=59&t=3090
Re: ST4000NM0035
October 18th, 2021, 3:07
here is the 8TB seagate ROM, didnt work the F3 rom explorer on it, still UNLOCK ERROR whent i try to fix it
ST8000NM0045-1RL112 - ZA1E4YTW.rar
(490.62 KiB) Downloaded 982 times
Re: ST4000NM0035
January 31st, 2022, 15:02
i find anothe type of drive but i think the fw its different, i will attach the ROM and logs here, dont work like that one from the past,
on the label its G003, inside two of G00A
maybe someone have an idea
Z1Z2YGJN.rar
(205.45 KiB) Downloaded 898 times
log.log
(13.24 KiB) Downloaded 797 times
terminal data.txt
(332 Bytes) Downloaded 864 times
Re: ST4000NM0035
March 31st, 2025, 11:33
sir
i want to buy
F3 ROM EXPLORER
can you help
please
