 Post subject: Ressources for WD Sequoia family WD1600AVBB-63SYA0
PostPosted: June 28th, 2026, 14:40
I'm searching for resources (ROM and loader) for WD Sequoia family drive.
WD1600AVBB-63SYA0 is the exact model-name.
My case have a burned PCB (CPU and spindle-motor-chip) and no external ROM. So I can't get it from original PCB.
This model seems to be very rare... I can't find a compatible ROM to get SA-access via loader to read the ROM-copy from SA.
Maybe somebody have resources for this drive?
Many thanks and greetz from Poland, Karol
 Post subject: Re: Ressources for WD Sequoia family WD1600AVBB-63SYA0
PostPosted: June 28th, 2026, 16:11
Did the original preamp survive? Usually when the motor controller and MCU are damaged, this suggests that there was an overvoltage on the 5V input, which in turn puts the preamp at risk.
PostPosted: June 28th, 2026, 16:20
First, I need the right ROM.
PostPosted: June 28th, 2026, 16:51
I would contact @michaelchiklis and ask him if he still has the ROM from the following job:
https://forum.hddguru.com/viewtopic.php?f=1&t=28534
PostPosted: June 28th, 2026, 17:17
I asked him, thank You!!
PostPosted: June 29th, 2026, 6:12
Sorry, i can't find it.
My firmware database:
PostPosted: October 10th, 2026, 3:39
Will any of these do?
PostPosted: October 10th, 2026, 4:11
Checking the preamp is just as important, starting the drive with a donor pcb and bad preamp puts the data to risk, no matter what rom the pcb is running...
