 Post subject: WDC WD40NDZW and WD40NPJZ zeroed sectors
PostPosted: October 10th, 2026, 3:24
Hello all, I got two similar drives with zeroed out sectors. I got all modules including 190 backed up and heads seem to read write fine. i tried the Ace T2 recovery methods. still could not get any data structured nor RAW. Any Ideas please? Much appreciated.
 Post subject: Re: WDC WD40NDZW and WD40NPJZ zeroed sectors
PostPosted: October 10th, 2026, 15:22
i'm not pc3000 user, i use mrt instead.
Often, when cloning these SMR drives, the process pauses for several seconds before resuming; however, it frequently happens that, upon resuming, the drive clones sectors as if they were zeros (in mrt those sectors are mapped with cyan colour squares). When analyzing the logical content on the destination drive later, you might find that much of the data is missing or that the files won't open.
The trick in these cases is to be very patient and try to limit the number of sectors blocks being read (instead 256 sectors x block i use 8 sectors x block); unfortunately, this significantly slows down the cloning speed, but it is the only solution i have found for when these HDDs are highly unstable.
It is necessary to read again those "empty fake sectors" with more stable DE configuration.
I don't know if PC-3000 offers a different solution, but using MRT, this is the only method i've found for these situations.
Perhaps someone who uses PC-3000 knows some another tricks that the tool can offer?
My firmware database:
PostPosted: October 12th, 2026, 11:26
Thank you, In PC3000 DE you can scan files in RAW format using PBA. Tried that too. Nothing so far
PostPosted: October 13th, 2026, 7:21
Recovery depends on whether the original 190 module remains intact. Any read or write access modifies low-level data. Every read/write operation and every power cycle alters the 190 module. Please halt all operations immediately. If the data on the drive is critical, it should be shipped to a more professional data recovery lab capable of this repair.
PostPosted: October 14th, 2026, 2:02
The WD40NDZW gives
"Host Debug Stop Log..................... : 010D (TRANSOVL) BAE1 3DA
DEBUGSTOP code 0x16086, param 0x00000001, flags 0x00000021 Unknown debug stop code
Power on Hours: 32 (1d, 8h)"
on log at start up. Am assuming it has to do with Translator.
PostPosted: October 14th, 2026, 7:30
Protech wrote:
The WD40NDZW gives
This TRANSOVL error 010D on WD40NDZW is indeed a **Translator Overflow** issue of the SMR secondary T2 translator.
This model is SMR, the translator relies on module 190. Repeated power cycles are extremely dangerous and may corrupt module 190 permanently, which will make data unrecoverable.
Do not power it on repeatedly. The recovery workflow needs to rebuild the SMR translator via PC3000 WD utility under write protection first, then make the disk image.
PostPosted: October 14th, 2026, 23:06
I always disable write access on mod 190, then i virtually rebuild T2 on ram before starting cloning.
I use MRT to do this, but often this smr drives stay unstable so i need to clone slowly (8 sectors x block).
PostPosted: October 15th, 2026, 3:10
sixsweets wrote:
Protech wrote:
The WD40NDZW gives
Thank you, there's a backup of the original modules before any rebuild was attempted. Will that help the possibility of file recovery?
PostPosted: October 15th, 2026, 8:09
Protech wrote:
sixsweets wrote:
Protech wrote:
The WD40NDZW gives
Yes, pre-rebuild module backup is helpful. But since I have not inspected the physical drive, I cannot make a definitive judgment on the final recovery chance.
PostPosted: Today, 1:55
Thank you, Heads were checked in the head map and the read/write test, and they pass. If you mean something else (platter surface, SA zone reads, preamp), say what and I’ll run it.
Users browsing this forum: pepe and 34 guests
