 Post subject: How to connect the hard drive terminal USB-3 WD10JDRW-11C7VS
PostPosted: Today, 14:20
I have a WD USB-3 WD10JDRW-11C7VS0 with PCB 810082 hard drive from 2026. How can I connect it via Terminal to reprogram the BIOS ?
I have already removed four capacitors: C112 and C114, and then soldered a Chinese PCB board to unlock the ROM and convert it to SATA (see photos). The drive is detected in SATA mode and in SATA backup, but I cannot read the ROM using the Boot ROM (Com port) option.
I consulted the WD manual: it indicates connecting the RX, TX, and GND pins. I made this connection, but I still cannot read the ROM using the Boot ROM (Com port) option.
Thank
 Post subject: Re: How to connect the hard drive terminal USB-3 WD10JDRW-11
PostPosted: Today, 15:17
Maybe you need this?
https://www.hddoracle.com/viewtopic.php?p=17079#p17079
Your adaptor appears to be a 3.3V type, whereas the HDD PCB would be operating at 1.8V LVTTL levels.
PostPosted: Today, 15:31
the old methods to access rom thru serport do not work on the locked MCUs. You need to use a programmer device to read/write flash on these. Once the pcb has an unlocked rom flashed, ROM is accessible thru VSC.
