 Post subject: WD 4000AAKS change capacity
PostPosted: November 6th, 2007, 23:44
dear all,
Please help me change capacity and recovery data on
WD 4000AAKS -00TMA0,
date: 03 AUG 2007 M,
DCM HARCNV2AB,
S/N WMAPW1406599.
I used PC-3000 for windows with ver 2.27, do search module in SA to find module ID (02), but i not success, all data in SA is zero, some driver with model WD xxxxAAJS and WD xxxxAAKS or WD xxxxAAKS is the same result, i know this model don't support on PC -3000 ver 2.27 for window, but with more drive that don't support i used this method to change capacity and S/N success, because module ID often in cyl -2, sector 0, or 5 although you can't read module dir to show all modules.
Please help me!!
 Post subject: Re: WD 4000AAKS change capacity
PostPosted: November 7th, 2007, 12:54
This is Tornado.
It's not yet supported by PC3000 UDMA and it will never be supported by PC3000 PCI.
There are 2 ways you can modify capacity: HPA and DCO with MHDD.
PostPosted: November 12th, 2007, 2:16
Starling wrote:
This is Tornado.
Thanks Starling :P
