Discussions related to PC-3000
Please no pirated software here!
disconnect head 0 on WD1600BB
June 13th, 2008, 20:36
hello,
I have WD1600BB-00GUC0 with 0 head defective,I tried to disable it but after disabling it drive can't read or write SA tracks.
I found this problem in disconnecting head 0 on this family only in WD drives.
for example WD1600BB-00GUC0 has 4 heads from 6 when I disconnected head 0 there is 3 heads from 6
the worked heads is 1 4 5
but drive hanged when logged in pc3000 WD program or salvationdata WD doctor
Re: disconnect head 0 on WD1600BB
June 13th, 2008, 21:59
In this family you can disconnect any heads, except head 0 and 1 .
June 13th, 2008, 22:09
why this family certinely
June 15th, 2008, 7:10
Because this is the head that reads the SA .
June 16th, 2008, 4:37
but u can disconnect head 0 in any WD hdd and make head 1 the first head
June 23rd, 2008, 10:49
how just by editing head map or is there any other procedure ?
